New intake manifold???
Started by Tarzan, July 05, 2008, 05:57:49 PM
Tarzan
Want to buy the Edelbrock rpm intake manifold for my 440 block, but I have heard that it wont fit my 69 charger.
Is this true? That it wont fit because of the height of the intake. I have the holley sd and it should not be much higher than that + I have a drop base for my air cleaner as well.
If this wont work, what should I get instead of the rpm intake? Looking for the same effect as the rpm..
Rolling_Thunder
i believe the performer RPM will wit with a drop base air cleaner - you can always use a 2" tall filter.    :2thumbs:
FLG
If you use the drop base air cleaner make sure you go with a K&N cover with the filter built on the top...the drop base sits to close to some carbs starving them of air.
The RPM manifold will clear with a 14x3 air cleaner assembly that has a 1.25in drop base.
If I had an SD and was looking for a little more bottom end power/throttle response i would install a 1in 4 hole spacer and use the above mentioned air cleaner assembly.  :Twocents:
Tarzan
Charger-Bodie
Quote from: Tarzan on July 05, 2008, 07:22:53 PM
This is the K&N filter I have (dropped) + the 1401 filter top.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=KNN%2D60%2D1280&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=KNN%2D66%2D1401&N=700+115&autoview=sku
So If I get the Eddy rpm intake it will fit without any other problems????
I have an eddy rpm on my 505 stroker. I used the ford motorsport(reccomended by Chris 6t9) drop base bottom and the unsilenced factory style top and a k&n filter in the stock size.
I would be looking at the Street Dom intake similar powerband with lower height
68charger440
Quote from: Charger-Bodie on July 05, 2008, 07:28:52 PM
I am looking to add a 1/2" phenolic spacer to my setup to deal with some vapor lock issues.  I have the eddy rpm intake also on my 500" stroker.  Do you have 1/2 " extra clearance on yours that you could fit a spacer in there under the carb? Mine has a Holley 870 Street Avenger.
When someone is absolutely 100% sure they know exactly what your problem is and how to fix it, it's time to ask someone else!
BSB67
Quote from: Tarzan on July 05, 2008, 05:57:49 PM
Does everyone here except me know what he has motor and drivetrain wise?  A lot of recommendations here.  I always thought that the motor might have something to do with choosing the right intake. :shruggy:
Sorry for being silly....carry on.
11.68 @ 120.2 mph
fy469rtse
I'm with BSB67, motor stock ? rebuilt , got a cam selection ready for upgrades ? heads,
dominator is a single plane , that will cause a whole lot of other issues on a ? stock engine cam set up
68charger440
Before you guys get too upset on this please note that it is a six year old post.  I just resurected it by asking the question about the spacer.  For that question I don't know or care about his build other that the fact that it was a 440 with an eddy rpm intake.  I just needed to know if it would fit with an additional 1/2 inch spacer under the carb.  So while you may have a good point it is irrelavent at this point since the original post was dead.  I would have started a new thread, but I asked and Troy said it is better to redirect an old thread sometimes rather than reinventing the wheel.  Maybe I shouldn't have resurected this one.  I thought it might cause some prolems.   :shruggy:
BSB67
Quote from: 68charger440 on August 19, 2014, 09:19:44 PM
Thanks....missed that.  But in staying with my theme of being a jerk tonight, I have to ask, can't you just measure if you have clearance?  For the time it took to ask, you could have measured.
11.68 @ 120.2 mph
68charger440
I did measure it and it is so close that I wanted to get a little reassurance from someone who had the same setup if I could.  I ordered the spacer anyway and will just be real careful when closing the hood for awhile.  I think I will be lucky if I have a 1/4" of room once it is in.
polywideblock
quick way to see how much space you have is to use a 2"-3" square piece of the green foam that florists use to hold flowers in place .it squashes down without damaging anything and stays at whatever height the space in-between is so that you can get an exact measurement  :Twocents:
have used it for years to gauge air cleaner to hood distance    :yesnod:
  and 71 GA4  383 magnum  SE
BSB67
Quote from: 68charger440 on August 19, 2014, 09:57:15 PM
Right.  And the problem is that any little difference in production tolerances could be the difference between someone having a 1/4" clearance and the next guy having a 1/4" interference.  Your motor will sit higher by installing new motor mounts.
This I can tell you, it can work.
11.68 @ 120.2 mph
68charger440
Great idea!  I was trying to think of something that would crush down like that and I came up blank. :2thumbs:
Charger-Bodie
I just read in another thread that a guy used his camera phone to video the space as he shut the hood. Seems lik a really good idea to me.
68charger440
Quote from: Charger-Bodie on August 20, 2014, 07:55:21 AM
Might be worth a shot.  A snapshot. :lol:
A Styrofoam cup also works a measuring tool for hood clearance.  :icon_smile_big:
Make sure your driver side engine mount has been properly reinforced ;
http://www.dodgecharger.com/forum/index.php/topic,13216.0.html
68charger440
Quote from: firefighter3931 on August 20, 2014, 08:38:21 AM
Yeah, I've been down that road before with a broken mount and a big round hole cut into my radiator by the fan.
BSB67
Quote from: 68charger440 on August 20, 2014, 07:01:17 AM
Modeling clay, loosely crumpled aluminum foil.....
11.68 @ 120.2 mph
68charger440
That lightly crumpled foil was the best of all of the suggestions.  I just tried it.  It took very little pressure to collapse it  and it didn't spring back very much if any at all. Unfortunately, my original measurements were spot on and I will only have 1/4 inch of clearance.   Now, any guesses as to how much upward twist/lift there will be when I romp on the motor assuming I don't rip the motor mount?  :shruggy: I'll do Ron's suggested fix for that.
myk
'OP could always get a CH4b...
68charger440
Quote from: myk on August 20, 2014, 05:58:49 PM
I'm pretty happy with the street manners of the Eddy, so I would rather make it work.
flyinlow
I just pulled the SD off my 73 to put a RPM on it . I set the intakes side by side , The RPM is about 3/4" taller.
I have a RPM on the '70 with a holley and 3x14 drop base. Its close, but fits.
terrible one
Quote from: 68charger440 on August 20, 2014, 05:23:02 PM
I've done the reinforcement on the motor mount and can say that I literally have about 1/16" or less of clearance between the air cleaner and the hood skin and it does not make contact under load. With an insulation pad there would be no chance though. I don't think you will have a problem with 1/4" if you do the motor mount mod. Now the whole car lurches to the side when you romp on it instead of just the engine  :lol:
myk
Christ man I guess I'll just stick with a CH4B...
68charger440
Quote from: terrible one on August 21, 2014, 03:55:46 AM
That's great to hear.  My insulation pad is long gone and not at the top on the list of things I care about, so this is a good excuse to turn down the dial on my give-a-sh#%ter even more on the insulation pad.
68charger440
Well I installed the spacer and gaskets, and the air cleaner did hit the hood just barely.  So I broke out the high speed cutter and cut 1/2" off of the base of the air cleaner.  Filed off any burs and put it back on.  The high speed cutter and file worked so well that you can't even tell that it had anything cut off.  It works great and now I can breath a little easier concerning the clearance.  Mine was an aftermarket low profile Edelbrock air cleaner so it may not work on other air cleaners.
