Can't figure this out
Started by Mo Power, July 01, 2008, 02:03:48 PM
Mo Power
If someone who is very outgoing I need a picture of the inside of a drivers door for a third generation Mopar that has the remote mirror. Because I can't figure out how to route the cords to not get in the way of the window when it goes up and down. It's just been driving me crazy and all the junkyard cars I've looked at are ripped out so I can't look at them to figure it out.
1973 Charger SE
1972 Roadrunner-1 of 34 power sunroofs
          Crazy colors, Wacky decals, and Massive engines
                      That's what Mopars alll about
lyall
You should have two clips on the control cable
1 of the clips go below the top door hinge
the other one I can not remember it goes for sure :brickwall:
Hope this helps a little
71_Charger_R/T
There are two plastic push pins with wire loom loops on the end that hold it in place. One is just under the upper hinge as lyall said and the other is just below and forward of the remote control for the mirror.... here are some pictures that will hopefully help. (it's hard to get inside the door with my camera and the power window motor gets in the way.)
71_Charger_R/T
more pic's
