Holley
Started by Grip64, June 26, 2008, 04:00:25 PM
Grip64
Hello fellas, looking for some advice.
I'm about to install a Holley Red electric fuel pump, i would like to know if i need to use a return line with this pump ??
All help most welcome !!
Thanks.
mikepmcs
BLAM! Here you go.  Hope it helps.
Welcome by the way. :cheers:
http://static.summitracing.com/global/images/instructions/hly-199r7914-2.pdf
If it doesn't give you the correct info, the tech number is at the bottom of the page as well.
v/r
Mike
oldschool
Quote from: Grip64 on June 26, 2008, 04:00:25 PM
Thanks.
[/q
uote]
you do not need a return line with a red pump,or a blue pump either.
i dont think you even need a regulator with a red pump.
hope this helps :icon_smile_tongue:
1970 Charger 580" 4-sp
Grip64
 Got the pump up and running today, good fuel flow and pressure, but the pump feels HOT to the touch when its running, is this normal ?
oldschool
Quote from: Grip64 on July 02, 2008, 04:16:41 PM
[/quote
a friend of mine has one,and his runs kind of hot too.
i think to have a cool running pump,you will need a bypass type system. :laugh:
Grip64
Thanks for the info fellas, think i'll put some miles on it and see how it performs.
The Red pump can be run as a deadhead unit but it will run cooler and last longer with a return line.  :Twocents:
