Serpentine Drive Kits
Started by Foreman72, June 09, 2008, 03:50:52 PM
Foreman72
so i've been lookin at some serpentine drive kits from March http://www.marchperf.com/pg47.html and i was wondering what the performance advantages were or if it was a strictly cosmetic improvement.  I mean does anyone really have serious belt-creeping issues?  :shruggy:  the kit is pretty expensive so unless it provides substantial improvement the money is better spent elsewhere...thanks guys
Eric "Foreman"
Previous: 1972 Dodge Charger
Current: 2002 Volvo S60
"The steps of a man are ordered by the LORD, and He delights in his way. Though he fall, he shall not be utterly cast down; For the LORD upholds him with His hand.
=Psalm 37:23-24=
"But store up for yourselves treasures in heaven..."
=Matthew 6:19-21=
:pat
Foreman72
Eric "Foreman"
=Psalm 37:23-24=
=Matthew 6:19-21=
:pat
lisiecki1
from what i've gathered the serpentine kits are set up with underdrive ratios, so you get a nominal improvement in power.  For that reason and for the look I'm planning on putting a set on my 383 when the car is done...
Foreman72
Quote from: lisiecki1 on January 28, 2009, 03:47:15 PM
is it worth the 500 bucks tho :shruggy:
Eric "Foreman"
=Psalm 37:23-24=
=Matthew 6:19-21=
:pat
lisiecki1
from a purely horsepower driven standpoint i'd say no.....you can get a lot more power out of nos for 500 bucks....
the kit i'm after is 1100.....but that's only because i want the whole a/c compressor set up with it....
On a streetcar try to avoid underdrive pulley systems....it only leads to problems.  :Twocents:
Belgium R/T -68
Foreman72
so just get ahold of the stock pulleys? any other thougths?
Eric "Foreman"
=Psalm 37:23-24=
=Matthew 6:19-21=
:pat
lisiecki1
i believe march does have a set that is not underdrive....but now you're paying just for the look.......other than that, try to locate the stock stuff....i might have some stuff, what are you looking for?
defiance
Well, look, convenience of a (slightly) more reliable belt system, and easier belt swaps.  I've got the march system...  BUT - I don't know that I'd recommend it.  The march system isn't actually a true serpentine - it uses two serpentine belts, but it's configured like a v-belt system (no 'concave' curves, no tensioner pulleys, tension adjustments needed to install/remove).  Plus, the finish on mine started developing corrosion underneath the clear coat after less than a year with minimal exposure to elements.  I ended up having to wire brush all the coating and corrosion off, refinish them, and re-coat them.  Wasn't very happy about that...
There's another one out there that's a bit more expensive, but actually comes with some of the accessories anyway and I believe it's a true serpentine system.  Billet specialties I think is the name of the mfg?
lisiecki1
true....glad you posted defiance, i had no idea about corrosion issues with the march system....billet specialties makes a really nice kit, but i think that's getting into the $2500 arena.....i'll probably get the march system and refinish before installation....
Foreman72
Quote from: lisiecki1 on January 29, 2009, 12:32:19 PM
a 318 w ps...i have a/c but i don't think i'll keep it...yeah...thanks 4 the info guys.... :2thumbs:
Eric "Foreman"
=Psalm 37:23-24=
=Matthew 6:19-21=
:pat
lisiecki1
i have the factory a/c pump/clutch and brackets and hoses.....i'll have to see what i have in the way of pulleys this evening
defiance
Quote from: lisiecki1 on January 29, 2009, 04:33:55 PM
cool - truth be told, I've heard of other people with march, and never heard anyone else mention corrosion problems, so maybe I did something wrong, or maybe I got a fluke.  It does work fine, and looks good again now.
Yeah, I just looked up the billet specialties one - a/c and ps and you're nearly up to $3k!!!  wow.  On the other hand, it looks like it comes with the entire set of accessories, water pump, basically everything in front of the block, so I guess that's not as bad as just 3k for a set of pulleys...  but it's still insane.
I seem to remember somebody on moparts putting together a non-dressey kit with new OEM components.
Foreman72
Quote from: defiance on January 29, 2009, 06:59:39 PM
if you happen 2 find that let me know...i'd love 2 see it...i want something reliable and reasonably attractive...that won't steal power...that sounds like a good bet...thanks a ton man :2thumbs:
Eric "Foreman"
=Psalm 37:23-24=
=Matthew 6:19-21=
:pat
defiance
Actually, found two different ones on moparts -
Here's a thread where a customer talks about a kit he got from moparts member Duster499 -
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=3506162&Searchpage=3&Main=3499758&Words=%2B440+%2Bserpentine&topic=&Search=true#Post3506162
Another moparts member Jerry makes this one
http://www.superiordesignconcepts.com/bbserpentine.html
I dunno a thing about either of them other than they both appear to be OEM style components.
If you find out more, definitely post - I might be tempted to give up the shiney to switch to something with a true serpentine belt.
lisiecki1
if you do please let me know, i might be interested in your march set :2thumbs:
bill440rt
I bought one of those kits from Duster499 as well. Everything is VERY high quality. nitrousn is also a member here & told me about them.
The only thing I may do is give the parts another fine polish on a wheel and re-clear coat them. They were originally supposed to be powder coated, but I think (from memory) there was a problem with that so now he just clears the parts.
Instructions are very clear, and all components are very nice. Cheaper than a March set-up too, and I can still run a mechanical fuel pump. AND, the A/C compressor will clear my 6-pack air cleaner!!
:Twocents:
