found in valve cover
Started by roger01, June 01, 2008, 10:15:49 AM
roger01
what is it its 1 1/4 long by about 3/16 in diameter....and comes to a blunt point ....
Winged 1
Need a little clearer pix.
Eric
mikepmcs
That really doesn't look like a round of some sort because of the"whatever it is" around the casing on the back half and the size described to have a taper like that doesn't make sense.  But the shadow on the front half looks like the tip of a round.
Too small to be a CO2 cartridge....
What the heck is it??
v/r
Mike
bordin34
Do you have an missing bolts in the rocker shaft?
1967 Coronet Black 440 Auto
Mahwah,NJ
oldschool
it does not look like anything i've ever seen,in the valve train area. :scratchchin:
1970 Charger 580" 4-sp
GreenMachine
My guess is one of those pins from an engine stand that keeps it from rotating.
roger01
no bolts are missing ...and i im glad it doesnt look like anything from the valve train ......i also think its some kind of pin of some sort...im thinking maybe from one of those oil change pumps at a quik lube place ...that the previous owner took it to.... :shruggy:
tecmopar
If its hollow and has a hole in each end it may just be as you said, the tip of the oil nozzle from a Jiffy Lube gun or one of those places.
