Cam choice
Started by 73chgrSE, May 28, 2008, 11:48:35 AM
73chgrSE
I'm planning a 451 for my charger. If i have a 3.73 and a 3000 stall what would be a good cam choice. I'll probly get some eddy rpm heads too.
On a side note, what would be a good cam choice for the stock 400 and stock heads that's in there now, same gear, 2000 stall right now.
konigcharger
If you have no vision or creative spirit, you can always fall back on the way the factory did it.
Quote from: 73chgrSE on May 28, 2008, 11:48:35 AM
For that combo i would go with the Comp xs282s solid or the xe285hl hydraulic. Vegas Mike has the 282 solid in his 440 and it made excellent power. A 451 would be identical.
Here's the build and dyno numbers :
http://www.dodgecharger.com/forum/index.php/topic,6000.0.html
Something along the lines of the Engle K54 hydraulic would really wake up that smogger.  ;)
Rolling_Thunder
Well...    I hate Comp Cams...    had some bad experiences in the past - Engle for me    :2thumbs:
