Oil pump gear install
Started by RECHRGD, May 15, 2008, 07:22:29 PM
RECHRGD
Just got through pre-oiling the engine.  When installing the oil pump gear, is the slot that engages the distributor supposed to be horizontal or vertical at tdc when looking at it from the passenger side?  Thanks, Bob
13.53 @ 105.32
Charger-Bodie
parallel with the camshaft.  :yesnod:
RD
Quote from: 1hot68 on May 15, 2008, 07:25:10 PM
if its a small block, big blocks are just a hint canted up if looking at it straight on
RECHRGD
Thank you Gentlemen!! It is a 440 and yes it does go a little upward.  Bob
13.53 @ 105.32
I install them the same way as Brian and place the vac advance cannister paralell to the front of the motor. This allows for some fore/aft distributor movement when adjusting the timing. You don't want the vacuum can to limit the distributors movement.
