# of axle splines
Started by 73chgrSE, May 12, 2008, 01:52:02 PM
73chgrSE
I'm shopping differentials and i notice that some are for different # axle splines. How many do I have with my stock setup? 73, 8 3/4 489 case with 2.76 open diff.  :icon_smile_question:
mikepmcs
489 case only came with 29 or only 10 spline yokes
If the pinion nut takes a 1 1/8 socket, it is a 10 spline. If the pinion nut takes a 1 1/4 or 1 5/16 socket, it is a 29 spline.
swiped from moparts tech archives.
v/r
Mike
The OP asked about axle splines; all 8 3/4" axles have 30 splines unless the carrier is changed to aftermarket.
mikepmcs
Oops,
Thanks John for setting me straight.   :cheers:
v/r
Mike
73chgrSE
73chgrSE
Do i have a "fine spline" pinion? I'm looking at ring and pinion gears and one says it's for a 8.75 w/489 case with fine spline pinion.
mikepmcs
Actually I now think my first post is relevant to the question you just asked. :2thumbs:
v/r
Mike
73chgrSE
Well, unless that's visible from the outside, i'm not in there to see the nut size, are there any other ways?
mikepmcs
Exactly.... the pinion nut on the outside of the yoke. Now I'm starting to second guess myself, but you take a socket as mentioned above and fit it to the nut on the yoke and then you will know your pinion size by the information posted above.  You will most likely have to move the driveshaft out of the way.
Maybe the 7260/90 ujoint dealy plus the measurement of the yoke gives some idea too but this is the way I did mine when I changed my pig last year and was wondering the same thing.
http://www.moparts.org/Tech/Archive/axle/9.html
http://www.moparts.org/Tech/Archive/axle/11.html
v/r
Mike
