magnum wheels
Started by cgkoch, April 05, 2008, 11:15:44 AM
cgkoch
I bought a project  74 Charger , and after removing the lug nuts the front wheel won't come off. I sprayed penetrant between the wheel and rotor with no luck.   How do I remove the center cap?   what could be the problem?  both front wheels are stuck. I haven't tried the rears yet.   Thanks
UFO
The magnum center cap are held on by two screws installed from the back.
terrible one
Man, that sucks about the caps only being able to be removed once the wheel is off!
Had this problem with my back wheel, rusted on pretty good. I used a 3 prong puller to get it off, which you could do if you didn't mind destroying your center caps. Try letting it soak with PB Blaster for a few days then get under there and kick the shit out of it. This is what we did on my friend's Sport Fury and it worked well.
Leave the lugnuts a little loose and take it for a short slow drive, do a couple of tight figure 8's and the wheel should break loose.
terrible one
Quote from: John_Kunkel on April 05, 2008, 02:52:54 PM
Hey! Much better of an idea than mine haha.  :2thumbs:
cgkoch
Thanks for the advice, since the engine is out of the car ,  I could get the neighbor's kid to push me down the street!   This is my second project car.  great forum site, I could have used one for my Dart.    thanks again.
