Help with engine ID
Started by Paul G, February 24, 2008, 10:27:22 PM
Paul G
Can someone help decode these numbers?
ID pad on left side front of block: J 440 HP   9  15
Numbers cast in to right side of block just below the head: 3698830    440   7 (the 7 could be T)
Its a 440 but can anyone tell the year and build date?
Is there supposed to be a VIN number on the block somewhere?
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
69CoronetRT
Quote from: Paul G on February 24, 2008, 10:27:22 PM
J = 1973 model year
440= CID
HP = HP assembly
9 15 = engine assembly date of September 15th, 1972
The VIN should be on a pad on the passenger's side just above the pan rail about 1/3 of the way back from the front of the block.
3698830    440   7 = casing number for 72-78 440. The 7 is the core revision number.
Hope this helps....
