Plus sizing?
Started by 69chargerboy, February 07, 2008, 03:48:00 PM
69chargerboy
Does anyone know how to "Plus Size" wheel/tire combos? If I were to increase my wheel size from a 14" stock to a 16" or greater, how would I calculate the best wheel/tire combo so my speedometer to read a correct speed when I'm driving? Thanks!
My MoPar Family:
1968 Chrysler 300
1968 Coronet 440 4-Dr
1968 Coronet 440
1969 Charger
1973 Charger SE
1988 Dodge Custom 150 Pickup
Mass_Mopar
The only way to keep the speedometer accurate is to maintain the same overall diameter (tire diameter) which is unlikey if you're starting from 14" wheels.  You'll probably end up having to change the speedometer gear in the transmission, which isn't as hard to do as it sounds. :cheers:
-Nick
70 Charger 500 383/833 pistol grip 3.91sg
71 New Yorker 440/Auto
04 Ram 5.7L 4x4 5spd 3.92 Auburn Posi
Old screen name MA_Young_Gun
It's mostly a ball park figure but the way I always understood it is something like this: Try dropping down in aspect ratio (the part between the '/' and the 'R') by 10 and going up in width by 10 for every inch in rim diameter. For example, a "Plus 1" from a 195/80R14 series tire is roughly a 205/70R15 and a "Plus 2" is about 215/60R16.
An easier way is to use a tire calculator like this one:
http://www.1010tires.com/TireSizeCalculator.asp
Put in your original tire size in the top set and the tire size(s) you're interested in down below. Once you submit the form you'll get a chart showing the differences in your selections. The key part is "Revs per Mile" (which is directly related to diameter).
Musicman
Here's a real nice calculator//comparetor for you... http://www.rims-n-tires.com/rt_specs.jsp
0X01B8
Quote from: Musicman on February 07, 2008, 08:32:42 PM
That's a good one.  Another one, in the same general topic --> http://vexer.com/68rt/speed.html  Under tires, click on 'profile.'
l8rg8r
What size 14" tires are you running now
69chargerboy
Quote from: l8rg8r on February 13, 2008, 02:11:11 AM
Well, I'm not running anything right now, but the car is currently being restored, I'm looking to buy new wheels and tires.... :2thumbs:
My MoPar Family:
1968 Chrysler 300
1968 Coronet 440
1969 Charger
1973 Charger SE
l8rg8r
OK if i had a tire size i could tell you what size 16 is the same diameter
basarowich
Does anyone know if there are any threads regarding replacing the seals on the speedometer gear?
