6pk or 4brrl
Started by 70_charger, January 12, 2008, 07:55:35 PM
70_charger
Gonna build a stroker(500+ ci) ! what is gonna get me better performance the 6pk or a holley or BG 4 brrl?
Personally, I'd put a four barrel on there for best performance and widest manifold choice.
Steve P.
I agree with Ghoste.  The WOW factor for the 6-pak is cool, but,,,,,   :iagree:...
Steve P.
Holiday, Florida
Like the others have said...a well tuned 4bbl will make more power.  :yesnod:
And provide fewer tuning headaches over the long haul.
70_charger
man that was easy thanks
70sixpkrt
I vote for the 6pk. I am using the ProMax stuff and have not had to adjust anything on the carbs. yet. I also love when the outboards kick in.
charger50071
I currently am running a 6-pack, some days it runs great other days like crap. At 2800.00 bucks for an all new setup, good thing it looks cool or I'd put the 4-barrel back on.
1971 Charger 500 383
1971 Charger RT 440-6
1965 Coronet 500 426 wedge
1960 Phoenix D-500 convertable crossram
Dodge Don
Quote from: 70sixpkrt on January 13, 2008, 05:32:22 PM
I agree
SeattleCharger
four barrel,   but six pack sounds cool
Rolling_Thunder
The 4bbl will get you better power in the long run - but the 6 pack is by no means a slouch - plus the 6 pack has the big "wow" factor. A single 4bbl will also get you more power than a dual 4bbl set up as well...      The 6 pack is usually a tuning nightmare (new carbs have the outboards adjustable and helps alot) but the six pack will also cost a bit more....
I'm going through a similar dilema - I am deciding if i should build a stroked big block for my RR or or build a A12 clone with a stoked six pack...     not sure at the moment.
Ricky, your's was dialed in on the dyno....not surprising that there would be no further adjustments needed  ;)
On a hot 440 type build the 6 pack with good parts (Metering block>center carb & Adjustable plates>outboard carbs) the tune can be dialed in pretty good.....close to a single 4bbl setup.
On a 500in stroker the 6pack manifold becomes the cork and doesn't move enough air to feed the bigger displacement. The 6-pack can still be made to run good on a stroker but you will be leaving some power on the table.
Fwiw, i like the 6pack setup and for visual appeal it kicks butt ! Ricky's build proves that 500hp from a well built 440 is easily attainable with a properly set up 6-pack induction system.  :2thumbs:   It's just not the "hot ticket" if you're chasing every last ounce of HP potential out of the build.  :Twocents:
jerry
i have been driving a factory built 6-bbl car since 69 and never had a problem.wouldn't own a 4-bbl car, 6-bbl is fast enough.always gets the job done.talking about a stock engine . :yesnod:
68charger383
I'd go for the 6-pack, get the perfromance and the wow factor.....Nothing like the feel of the outboards suddenly kicking in on a 6 pack!
1968 Charger 383(Sold)
2003 Dodge Viper SRT-10
Rolling_Thunder
Quote from: 68charger383 on January 15, 2008, 10:33:08 AM
also 6 packs get better highway milage   :icon_smile_big:
70_charger
Im putting this on a stroker,Id def. put one on a stoker . Ive heard of very many peeps running 6 paks on strokers . :brickwall:
AKcharger
My 470 s going to run a six pack from promax. I've heard about the tuning woes but with new technology and the ability to dyno the whole set-up before it leave the shop i'm there. Now if I was on a tight budget I'd go with a 4 bbl...but right now, i'm not  ;D
Rolling_Thunder
Quote from: 70_charger on January 15, 2008, 06:50:01 PM
look at most of the FAST class mopar participants...   Alot of A-12 clones   :2thumbs:
Do you think if the FAST class rules allowed them to run a big single plane with an aftermarket four barrel they'd still all be using the 3X2?
Quote from: Ghoste on January 21, 2008, 04:38:07 AM
The factory manifolds and 2.5in exhaust pipes are the big cork...a single plane might make a little more power but w/o headers and bigger pipes you will not realize the full potential of a single plane/double pumper induction package.  :Twocents:
Okay, let me rephrase that, do you think the FAST class guys are running the 6 pack because it's the hot ticket or because the rules say they have to?
SeattleCharger
Quote from: Ghoste on January 22, 2008, 07:26:39 PM
Is that multiple choice?
It is in this context.  :icon_smile_wink:
I believe it's more to do with the rules and what appears "correct" because this is after alll a "stock appearing" race class and the 6 packs are pretty cool to look at. All the really quick guys that are competitive in this class are running high compression stroker motors that run on race fuel so the stock 6-pack and stock HP exhaust manifolds & stock heads are really holding them back.....probably to the tne of at least 100 hp or more which could be achieved with better heads/intake/carb and headers/exhaust.
SeattleCharger
so about what kind of horsepower range are these guys in with strokers and hp exhaust manifolds?  high four hundreds?
Quote from: firefighter3931 on January 23, 2008, 08:27:00 AM
Exactly my point.  There a lot of A12 clones in the class because it's an advantage within their rules.  If the rules said any intake or carb, most of those guys would lose the Six Pack setups in the time it took to install the big single four.
Quote from: SeattleChargerDog on January 23, 2008, 01:26:21 PM
The better wedge 6-pack strokers are making in the 600hp range....amazing considering the restrictions placed on them.  :2thumbs:
Quote from: Ghoste on January 24, 2008, 04:58:53 AM
The only real advantage is that the stock 6-pack setup is preferable to a stock 69 cast iron intake and carter carb. It's basicly the lesser of 2 evils.  :P Now if the could run any single plane intake and a nice HP series Holley carb...they would be all over it, i'm sure.  :icon_smile_big:
Musicman
I think a lot of this argument depends on the end use of the vehicle. Are you looking for street performance or strip performance? All things being equal, and assuming that the rest of the engine components are a proper match... the 6 Pack will deliver tons of torque and hp where it's needed on the street, while still providing great gas milage for everyday use. At the track however, a big giant gas guzzling 4bbl mounted on a single plane intake, and a big rough rider cam will generate more power at the upper end of the RPM scale where it's needed. A true track car isn't exactly a lot of fun to drive around town though. Most of them will rattle the teeth out of your head in about 10 Min's.
If I was looking for a good compromise and price wasn't a factor, I would take the 6 Pack any day of the week.  :cheers:
Mike  :Twocents:
Dodge Don
Sounds like some people have barrel envy  :pity:
70_charger
Builder told me single plane 4 brrl on the street for my setup would get me most power. He said 6pcks are good but the 4 was out performing it .
