head gasket
Started by Charger72SE, January 07, 2008, 09:55:18 AM
Charger72SE
can a car be driven a short distance with a blown head gasket?  need to know if a tow is needed or if it can be driven a couple miles
thanks!!
Chatt69chgr
If the head gasket is blown such that coolant is getting in the oil, then you would destroy the engine in short order.
mally69
I would rather see you spend 100 dollars towing it, than 3000 dollars on a new rebuild. Correct?
Charger72SE
thanks, guys, for the advise!!
