Dash question
Started by ryan053, September 26, 2007, 09:02:09 PM
ryan053
I just got my charger and i have some questions about the dash.   Most of the gauges dont work and i havent figured out why yet.  One question i have right of the bat is that next to the speedo on the right is supposed to be a switch.  What goes there.  Mine just has a big rectangular hole?
UFO
Well if this for a 68,that empty hole is for a rear defroster switch.
ryan053
yeah its for a 68 sorry i forgot to mention that.  and the defroster switch is missing.  There are no wires in the back window for a defroster though?
Rolling_Thunder
rear defroster was an  option...     if it was not optioned on the car the dash recieved a little plastic cover that snapped into the hole...     as far as i know that piece is hard to find
ryan053
ok well that news isnt so good.  Maybe ill have to make something up.
As for the guages, which ones don't work?  You may have a bad limiter.
lilwendal
PG Classic makes the filler piece for the defrost hole. 45.00
ryan053
so far i know the oil pressure guage, the speedo, the clock, and the alternator guage reads at around 20.  I dont know if thats normal.
smokinrt
Suggest you start by purchasing a Service Manual, you can find them on the internet all over under automotive classic literature.  I couldn't live without it.  Also buy a restoration book, one that referrs to car part numbers.  It will be so much easier when looking  for a true matching part, good luck,
SmokinRT
smokinrt
One more thing, start by replacing your limiter on the guage cluster before you even start fixing any guage,  it may solve a bunch of problems, than go from there. They have replacements at the local Chrysler parts counter.
HITMAN 149
Quote from: lilwendal on September 27, 2007, 05:06:38 AM
i picked one up from PG somewhere in the $35-$45 range...they do pop up on ebay every now & then.
actually i have to spray my PG piece to match my dash bezel that i'm re-doing... so that it'll match... the PG piece was a lil shiny/glossy compared to how the dash should be dull/flat. but the piece fit in real nice!! if it helps!?!?!?
68 Charger R/T, SOLD =/ sniffle sniffle
01 BMW 740i SPORT
01 Hot Rod Harley Dresser, SOLD =/ =/
ryan053
is the part just called a limiter or is it a voltage limiter?  also what does this thing look like.  id like to bring it with to make sure i get the correct one.
It's called a voltage limiter and it's a small metal can on the back of your dash.  It's rectangular in shape and about 2 inches long and .75 wide and maybe .5 deep.  They will be a lot cheaper from a place like NAPA than they will from Chrysler.  Also, you can get the service manual for your car on cd-rom from Mopar Performance.
