1/4 mile run
Started by mally69, September 19, 2007, 08:10:16 PM
what will it run in a 1/4 mile
12
12.5
12.7
13
13.2
13.5
mally69
going to the strip this weekend  for the first time take a guess what it will run
69 charger
440  30 over  with 10.4 compression
906 heads decked 7 thousanths not ported
1.5 ratio roller rockers
hooker super comp 1  3/4 headers
full 3 '' mandrel bent exhaust with an  X pipe
comp 292 dur .501 lift     244@.050   cam is (advanced)
4.10 gears
tci 3000-3500 stall  street fighter convertor
TM-7 intake
mighty demon 750
mopar coil and distributer (mopar chrome ignition box )
car weigh 3820 with me in it..
275/60/15 bfgoodrich radial t/a
Silver R/T
should be low 13's with better tires and good driver you shouldnt have problem breaking into 12's
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
69charger2002
i had a 440 standard bore but cleaned up, edelbrock performer RPM intake and carb, 906 heads, stock, 1 3/4 hooker headers, straight 3 inch exhaust dumping at the axle. 275/60/15 tires.. 4:11 gears. TCI 2800 stall converter. electronic ignition with accel super coil etc. doesn't sound TOO far off yours. i expected mid 13's it never got below 14.09. oohh if i had only had some drag radials...i was shocked with the slow time. of course my motor was a little more stock than yours.. and YES i know how to drag race i actually won the event that night against 32 competitors in the eliminations.. so don't hate with my 14.09 time. lol. all i'm saying is though it may feel like mid 12's, don't be shocked if it runs mid to high 13's
trav
Mally, the BFG street tires will kill your short times....expect LOTS of wheelspin off the launch. It should go somewhere in the 13's if you can get it to hook.  ;)
:iagree:  practice feathering it off the line.....dont mat it or you'll go up in smoke
mally69
I will let everyone know what my boat runs in the 1/4 when i get back saturday night ... I definatly have some tuning to do on the carb, needs to be leaned out a bit  but i think i ll let it go this time..
keep the poll going guys :popcrn:   thanks for all advice :2thumbs:
mally69
well they were only running 1/8 mile today so i didnt get to run in the 1/4  but   heres is what my time slip says.......
be honest,, tell me if its good or bad i wont be offended at all  :smilielol:
R/T   .268
60'    1.995
330   5.778
1/8   8.980
MPH 75.96
i ran 2 times but on the second run  my car started vapor locking so since i had to drive it home i called it quits.
mally69
Lunger
 well i used to have allmost the same set up. only diff from yours to mine where
1) i ran purple shaft 509 lift, i think it is a 292 duration
2) my iron heads had a stage 2 port from muscle motors in lansing
3) ran hoosier quick time d.o.t. 's 295 60 r 15's
this was about 8 years back
my 60' was 2.3 --------- yes i know burned the hell out of the tires but dam it was fun
12.75 @ 112 mph.
BULL OF THE WOODS
Nice run!  Seems to be in line with my car.
I was 8.744 at the 1/8  @ 81.64 MPH
1/4 mile was 13.550 @ 102.40MPH
Lunger
what rpm where you shifting at?  I was running it real hard, I think i was shifting about 6600 rpm. I wanted to see what it would do , i had my foot into it to see what rpm it would nose over at, but it just kept pulling, but when it hit 6600, i chickened out and shifted.
Oh and i made a error my MPH was only 110
sounds like my ported heads where the big difference uptop
BULL OF THE WOODS
mally69
mally69
Quote from: Just 6T9_CHGR.... on September 23, 2007, 05:46:55 AM
what gear ratio do you run ??
69charger2002
so if chris's ran a 13.55 and yours was just a touch slower in the numbers.. that makes for ABOUT a 13.70 run. i'd say you did good with that.. and it's very close to what i predicted   :nana:
trav
mally69
haha  :icon_smile_big:  im sure if i had more time at the track i could get better times not sure how much better but there is probably some room for improvement  :2thumbs:  i had a great time there and i am hooked on it ,   i cant wait to go again
Blakcharger440
Chris what are the specs on your car???
440 with approx 9.3:1 compression with 915 closed chambered heads, Engle K56 cam (224º duration with .504" lift), Edelbrock CH4B manifold, Holley vac Sec 750 with HP main body, stock HP manifolds with a full 2.5" Accurate LTD exhaust stock hemi mufflers, full manual reverse valvebody 727, 3.55 Sure-Grip rear, 255/60/15 RedLine radial tires.....wheww that was a mouthfull!
If I got better traction and was a bit more daring with my shift RPM's (shifted at 5500 max) I would hope to the in the low 13's possibly high 12's
Im hoping to make another track appearance this November at the F.A.S.T. race at Englishtown Raceway Park in NJ :drive:
mally69
chris your car is totally awesome mine looks similar to yours without the vinyl top and a few other things
mally69
another
