starter motor
Started by C500, September 04, 2007, 12:27:19 AM
C500
can someone please tell me if a 440 starter motor (part number 2095219) will fit a 318.
thanks,
kiwi
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
With the exception of some 4-speed Hemis and other manual trans installations all starters will interchange from '62 into the eighties.
BTW, the number you posted is probably a casting number, not the part number.
C500
chargerman68
Quote from: John_Kunkel on September 05, 2007, 03:53:19 PM
:iagree:
fired my starter then went to junkyard found a late model dodge grabbed the starter sitting in the trunk and put it in my charger;
now if i can just get it started...totally different topic....
