440 a/c removal
Started by roger01, June 18, 2007, 03:37:38 PM
roger01
i would like to take the compressor off my engine...... what will i need to do ....as far as pullys to make everything work ......i just want alt ,power steering and fan ....thanks
Charger-Bodie
you will need to get non a/c pulleys and braket set up all available at mancini among others.
roger01
non a/c for the fan and the crank..... or just one of them
Mean 318
both the water pump and the lower pulley. Like he said, you will also need a new alt bracket. I do know of guys that have made all the AC parts work by using spacers but IMO just spend 100-150 and do it the right way! Good luck!
gasoline_24
I will take those 68 Charger A/C parts off of your hands.
the A/C bracket is kinda a myth... you can keep the A/C alt bracket without problem.
The A/C alt bracket was changed from the Non A/C bracket just because location on water pump housing bolts, since Compresor bracket use the same NON A/C  locations, so A/C alt bracket was relocated to a deeper location.
Then you see A/C alt bracket location on alt in back of alt bolt hole and NON A/C alt brackets fiiting in front of alt hole.
However, for correct resto, of course needs to be changed
Water pump pulley is a need to match with alt, Then water pump belt iddler is not more needed, because alt will be the new iddler. Crank pulley just for right look too.
