400 N and P codes
Started by Nacho-RT74, July 20, 2007, 06:07:11 PM
I know 400 M code is 2 bbls but both N and P codes are 4bbls... what's the difference ?
ipstrategies
N code - 71 383-4 my charger is a 71 n code
P code - 72  400-4
M code - 72  400-2
In 71 the L code 383-2 which I have as a parts car
M    Special Order V8 1967
   440-6    1969
   400-2    1972-76
   318-4    1981-82
N    383-4    1970-71
   400-4    1974-78
   318-4 HD 1981-82
P    340-4    1968-69
   400-4    1972-73
   400-4 HP 1974-78
   318-2    1983-89
1971 Dodge Charger SE 383 Magnum
1999 Dodge Durango 5.9
1995 Chrysler LHS
pettyfan43
The n code engine is the standard 400 4 barrell. The P code is the HP 400. Not really sure all the differences but there are apparently two different ones.
Also I COULD BE WRONG!!!!! BUT I think the N code 400 is the big car/pickup engine, the P code engine is the B-Body Charger/RoadRunner and later Charger/Magnum/Cordoba  and also the engine that came in some police cruisers.
ok, dunno if between 72/74 really does exist a 400 4bbls what is not Magnum engine so "HP".
ipstrategies
Yes confusing,
I knew 70 & 71 N were 383-4 and 70 & 71 L were 383-2
72 had M400-2 and P 400-4 (lI almost bought 72 P code 400-4)
above 74 was not sure I had a 74 318 Charger for a little while but kept loking until I found what a I wanted a 71 383-4 N code
1995 Chrysler LHS
69CoronetRT
Quote from: pettyfan43 on July 20, 2007, 06:45:30 PM
You're right on...from 74-78 there were two versions of the 400-4bbl (N and P). One application for single exhaust C bodies and one with the dual exhausts or basically the HP version. The HP version had different a different cam some years. It all came down to application and availibility by state.
ok, now makes sense... Is just that on Rock auto website when yopu make teh search does appear on engine choose N and P whne you already selected Charger and as far I know no one 400 4bbl on Charger was non HP or magnum
69CoronetRT
Quote from: Nacho-RT74 on July 20, 2007, 10:33:35 PM
Depends on what year Charger we're talking about and where it was sold. The HP was N/A in California in some applications.
