help wont start
Started by chargerman68, June 16, 2007, 01:43:15 AM
supserdave
Timing is still off somehow. Like I said, you can have the firing order correct, but if your way off on where your number one is you won't be able to turn the distributor enough to get it to line up with the rotor.
I'd pull out the number one plug, check to make sure your getting a good spark, then find Top Dead Center. Take the distributor cap off, move the distributor to the middle of the travel that you have without the vac advance hitting the heater hose, and then put the cap back on and put number one plug wire where the rotor is aiming. Jump in the car hit the switch and it should fire right up!
chargerman68
will try that as soon as the batt is charged.i have been trying to get thsi going for over a week now.....really getting :brickwall:
supserdave
I hear ya, trying to get my brothers pickup going the other weekend we fought the same thing, finally took the time to actually find TDC and not guess where it should be, and it popped right off.
Like I said, your close man! :popcrn:
chargerman68
thanks for the help on this
later
chargerman68
ok now i fix one problem then another comes up...now the starter is just clicking and sparks on it...has correct hookup and was working.now nothing.i am really getting tired of this crap. :brickwall:
i think i just fried my starter.. :RantExplode:
EffinDuff
Did the cable loosen up by chance?  May be at the starter or the battery.  kinda a dumb question but after alot of this  :brickwall: :brickwall: :brickwall: you lose sight of the little things.
chargerman68
no both the batt cable and the starter relay tight..
chargerman68
with the light off in the garage,i can see sparks from the inside  of the starter,any ideas.did i fry it?
deputycrawford
     I would say you fried it. Take it off and into a parts shop for a test. Then buy a starter for a 1995 Dodge Dakota 6 cylinder. That is the mini starter everyone talks about. It also turns the engine over much faster.
     Then turn the engine over until you find TDC. Then put a ratchet on the crank pulley, turn the engine to the 10 degree before TDC mark. Put the distributor in the engine with the vaccum pod where you can adjust it. Mark the side of the distributor where the rotor is and put the cap on. Put the number one wire on the cap at the mark. Then follow the firing order counter clockwise of 18436572.
     Change the oil and plugs. Start engine and take it to 2000 rpms immediately and hold there for cam break in. Change oil and drive to show.
If it ain't wide open; it ain't running.        Rule number one in motocross racing: Pin it; row the gear box; and wait until you hit something.     At work my motto is: If you need me, call someone else.
chargerman68
thanks will do that in the am,do u know how much one of those dakota starters cost..do i need a core?
supserdave
440 source has them to, i think there 79 bucks or something?
chargerman68
well after confirming with the auto store starter is fried.i think that went i started using the ign switch instead there was alittle smoke from time to time,oh well there will always be more broken parts....anyone one has a big block starter laying around.
supserdave
I have one you can try if you come pick it up, but its in Iowa.... :eek2:
chargerman68
Charger-Bodie
it doesnt have to be a big block starter ....a slant 6 starter will work!!!!
mikepmcs
mid 90's Dodge Dakota 6 cylinder  will work from what I hear.  think it was said in this very thread... Call a salvage yard and get one.
v/r
Mike
chargerman68
68chargerboy
im telling you man the coil is wired up wrong, use your stock one and see if you get anyspark that way.  there is a certain way that your suppose to wire them msd coils
chargerman68
how have spark just a fried starter :RantExplode:
chargerman68
Charger-Bodie
no thats a 4 banger starter.
chargerman68
EffinDuff
If it is the 95 Dakota starter like the Deputy says (which i'm not disputing i just dont know) then this should work.
http://cgi.ebay.com/ebaymotors/1991-1995-DOGDE-DAKOTA-STARTER-V6-8-3-9-5-2L_W0QQitemZ200118892921QQihZ010QQcategoryZ33573QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
In my opinion for $65 plus $20 in shipping for a reman you might as well get the new starter from 440source.com for $79.95 at least its from a reputable company and not some potential ebay chop shop.
Then again its not my money  :boogie:
chargerman68
thanks i will look into it
EffinDuff
