horn wiring
Started by 69 rt, June 09, 2007, 01:14:04 PM
69 rt
HI,
I have a 69 charger and am wondering if anyone has a wiring diagram for the horn button. I removed the wheel and I have a broken wire. I can see it fits inside a small plastic slot but I think some of the parts could be missing.It looks like it should be connected to a pin of some sort that would make a ground when the horn button is pressed. Any help would be appreciated.
Shakey
Hope this helps - it's all I've got.
The wiring diagrams have been posted here before.
69 rt
Thanks for helping, but what I need to see is a picture in the area of the turn signal cancel switch, where the wires enter from the steering column. Any help would be greatly appreciated. Also can you still buy these parts?
69 rt
I wanted to post some pictures of my problem area, I hope this helps and if anyone has the parts I need I will gladly buy them.
69 rt
I don't know why the picture is so large but the wire to the right is broken and I think there is a pin of some sort missing. I think my computer is on the blink!!
