clear coat ?
Started by srpntlair1, May 27, 2007, 08:44:49 PM
srpntlair1
base and clear are done in engine compartment, actually very easy to do, I was surprised. my question is clear coat looks great and doesn't need to be wet sanded, unfortunately I got a damn bug in the fender while clear was setting. what is best way to po;ish it out? can only a small spot be wet sanded? will it blend?
dads_69
Use a razor blade to remove bug, but first scrap it on ground 3 times then turn it around and gently scrape meaning the height of the bug needs to be knocked down first, then prep area size of a coffee can lid by wet sanding w/1000 or 1200 grit, air brush or use same guns for painting/clear, just turn down your air pressure, base then clear and use blender at edges of area cleared and light buff but not area that you used blender on and you should be OK. You can melt them together in all actuality w/out having to buff much if at all.
Mark
Hey, you can hate the game but don't hate the player.
