spacer blocks on 73/74
Started by Nacho-RT74, May 23, 2007, 02:43:14 PM
where do you install spacer block on 73/74s  with isolator clamps ?
I never have seen spacer block to isolated springs, just the tipical aluminium block with same stud size of spring one that won't be possible to use on top the isolator clamp, so just between spring and top section of clamp...
would it be the only way to add a spacer block on 73 and laters ?
moparguy01
get with the program and remove those crappy isolators?  :icon_smile_big: to lower the car it still has to go between the housing and the leaf spring. Otherwise it really wont make a difference.
if I remove isolators car will get higher because pedestal are smaller, and will need to modify pedestal guide hole and repair the 71/72 sway bar plate I modified once etc... also search for the lower shock absorver bracket/plate to myach with sway bar U bolts holes etc...
too much job, plus I LIKE TO BE COMFORTABLY SO THEN i LIKE ISOLATION STUFF HEHEHE...
