wire for water temp
Started by chargerman68, May 20, 2007, 04:49:31 PM
chargerman68
have the wire for it but nothing on the water pump to connect the wire too.
440/727
COKE
The water temperature sender is behind the alternator bracket.
It need a rounded female therminal,similar in form to the angle spark plug wires.
69´Charger R/T,440 ,4-speed,Dana 60 3.55.
chargerman68
i think it goes where i got the cap
The temp sender screws into the waterpump housing, through the alt bracket hole.
The wire should be a push on type plug...the sending unit, although it appears to be threaded for a nut, is NOT.....dont ask me how I know.
that bracket is for non A/C cars... A/C cars sender unit is at a side of that bracket since bracket location is different.
Still screws into the same place in the WP housing though ;)
Of course LOL... is just in case he will search the bracket hole and doesn't find hehehe
resq302
What is supposed to go where that pipe plug is then?  That is where mine is. ???  I have also seen a lot of other cars there as well too.
Brian
An emission controls device... a sensor as far I can recall righ now.
resq302
not for 1969 other than a coolant temp sensor that I currently have there.
Brian
Quote from: resq302 on May 21, 2007, 06:03:32 PM
Nothing on our cars Brian.....plug should be an inverted one though (female)
Must have missed that detail on the search for the "non stock item" :scratchchin:
resq302
aww crap.  One more thing I have to fix.   Chris, can you snap me a shot of what it looks like?  Is it the one that has like the 1/2 inch rachet or extension would fit into and not over?
Brian
Yes Brian thats the one.....you cant use my car for reference tough....I have a second electric sending unit in that hole for an aftermarket gauge.  I dont have any good pics of before I had this though
Charger-Bodie
the plug that goes there accepts a 3/8 drive socket extention, whats in the hole that the sending unit belongs in now? a plug? or is there no hole? because some allum housings dont have the hole there but on the other side of the housing like an early bb ie 65 ect.
resq302
Mine has a hole but there is a brass reducer adapter in there to get it down to the size that the temp sending unit sensor is.  It is a steel factory piece so I guess with any luck I can go to home depot or lowes and pick up the correct plug.
Brian
BrianShaughnessy
On some aluminum WP housings,  there's a place for the temp sender right about where that wire is laying in the pic above.
RDR-838
I've installed a new temp sending unit and still get no reading on my guage. While doing the install, I put teflon tape on the unit's threads. Could this cause a problem?
I think yes... does need ground to send ground to gauge and you are isolating the ground ( negative ) input
