#1 spark plug wire ??
Started by MR.MIKE, May 10, 2007, 06:41:47 PM
MR.MIKE
can someone please tell me
where the #1spark plug wire goes on the distributor cap ???
or what wires are on the sides of the 2 clamps on cap :-\
68 charger 440
thanks guys :icon_smile_big:
strunzi76@verizon.net
BrianShaughnessy
How about a halfazz picture?   Basically #1 goes somewhere around 5 O' clock as viewed from the pass. side.
Charger-Bodie
it all depend on the oil pum shaft being installed correctly because even thou it SHOULD be at 5 oclock it could be elsewhere if the gear is not in right
MR.MIKE
brian,
thanks for the pic- i love fish net stockings !!!! :icon_smile_big:
mike
Big Lebowski
  And if it back fires, then you're 180 degrees out.
"Let me explain something to you, um i am not Mr. Lebowski, you're Mr. Lebowski. I'm the dude, so that's what you call me. That or his dudeness, or duder, or you know, el duderino if you're not into the whole brevity thing."
BrianShaughnessy
Quote from: 1hot68 on May 10, 2007, 09:26:48 PM
Yeaup...   At TDC the slot of the oil pump drive should be parallel with the camshaft.
MR.MIKE
yep,
i have a timing issue as well
didnt get to that yet
it's tough with a lil guy running around and another on the way
thanks for all your help guys !!!!
mike
this is the position needs to have on oil pump shaft to get #1 on right position with TDC on #1. Parallel notch ( or much as posible ) with crank on BB/RB engines
MR.MIKE
thanks nacho-rt74
you guys are great !! :icon_smile_big:
68chargerboy
i dident know about the oil pump shaft shold i take it out or will i be ok :-\
MR.MIKE
okay guys
now that  the wires are in all the right spots
the car cranks only.
how do i align oil shaft ?? ???
mike
Runner
the oil pump shaft doesnt "need' to be inline with the cam, it just makes it more uniform for people to find #1 plug location. i personally dont worry about it. the best way to find where #1 plug wire is, is to pull number1 plug out and turn the motor over until you feel compresion coming out the hole, then bring the engine to tdc pull and pull the distributor cap off. the rotor is pointing at #1 plug wire terminal.   if you do it this way, you cant be 180 degrees out.     good luck!
:iagree:
the oil pump shaft position is just a guide to get the spark plug wires same on all cars and is a way to begin with everything located.
Another reason to get the shaft on that position is the advance vacuum located where you have MORE ROOM to get the dist advanced or retarded on timming
GreenMachine
While you have your distributor out, you can see a portion of the cam gear through the hole. Your timing chain may be worn.
