Transmission Reverse Switch
Started by dvnen, May 01, 2007, 04:22:00 PM
dvnen
I recently converted from a column shift to floor shift and my reserve lights no longer work.  Also, I can put the car in gear without the key being in ignition - what else to I need to convert to get the reverse lights to work and shifter not engaged until the key in in the ignition?  Any ideas would be appreciated...thanks
what year car , each are different
dvnen
sorry car is a 74 motor and tranny are 69 if that makes a difference...thanks
floor shifter cars gear without key in ignition. Is not a fail, simply IT IS on that way
for reverse light, check at NSS switch on tranny if is loosen . Just in case it must be 3 prongs kind
