Brake pedal question
Started by toqwik, May 04, 2007, 06:40:29 AM
toqwik
I recently had some boxes of parts to my 68 charger stolen and in one of them was my brake pedal assy.  My question is, my car had manual brakes, with disc on the front.  I found a 68 in a junkyard but it is a power brake pedal assembly.  I want to keep  the manual brakes, but is the pedal assy the same.  Mainly, is the brake pushrod the same for both power and manual brakes?
The pedal assy is the same.  The pushrod is not.
The power brake setup uses a bellcrank assy where the manual brakes uses just a straight pushrod
toqwik
So can I use the same assembly and just change the pushrod?
Charger-Bodie
Quote from: toqwik on May 04, 2007, 10:54:49 PM
yes
#1 manual brake pushrod.....
#2 power brake bell crank assy
mikepmcs
so did you get the other 68 or what? :icon_smile_big:
toqwik
No, the other 68 is in very bad shape, I think if you tried to load it, it would break in half.  Just robbing off it what I can to help get some of my parts back.
toqwik
You don't want to sell that manual push rod, do you?
