vaccum question
Started by chargerman68, May 01, 2007, 09:06:24 PM
chargerman68
have a edelbrock rpm intake on my 440.looking around cant find any parts for the brake booster.there is also a hole in the intake is that for the line from the brake boosteer to the intake.if anybody has this setup or pictures of where it goes on a aftermarket intake please let me  know. thanks
If I'm understanding your post correctly, yes the PB booster gets its vacuum from a vacuum fitting usually screwed into the intake.  If yours is plugged up you need to remove the plug & get a vacuum fitting to screw into its place.
there should be a port for the brake booster on the intake , my friend is using the same intake & we had no problem hooking his up but I cannot remember where the port is exactly , the PCV should be hooked to the carb base so it is evenly distributed to all ports though not hooked to a single runner
