starting problem
Started by chargerman68, April 25, 2007, 12:37:11 AM
chargerman68
engine turns over no start.have fuel pressure and all ign wires are correct?any ideas
myk
Coil and or coil wire?  Ballast resistor?  Is there any spark?
Is not weird get loosen plugs on ECU or Dist plug
koshe
are you getting fuel to the carb? (plugged fuel filter?)
