trans shift kit
Started by Silver R/T, July 24, 2005, 12:50:18 AM
Silver R/T
what is best shift kit out there, brand etc.
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
TransGo works best in the Mopars
I have a friend that says you don`t even need one all the mods can be made with a kit at alll
CFMopar
I use the b&m and it works good.
1971 Charger SE 440 automatic
2014 Ram EcoDiesel Laramie
Runner
transgo tf-2 ,  those really cheap 25 dollar kits are a waste of money imo been there done that.
amidemon
Quote from: Ghoste on July 27, 2005, 12:28:22 AM
Agreed.   Transgo TF2.
3rd, I got one and I chirp through the gears quite nicely.
Duey
My TF2 works nicely too!  Make that 4....
73 SE Brougham, F3 , 440, 850 Pro-form, 727 w TA 10", 4.10SG
Silver R/T
Alright Ive got TF2 shift kit what else should I get to upgrade my trans?
2001 Ram 2500 CTD
RD
i have had a b & m shift kit in a tranny for 6 years without a problem.  I increased the throttle pressure to get good hard shifts.  works like a champ, ask buttermilksloth or moparguy01 if you want any opinions about my setup.
CFMopar
How did you increase the pressure?
Silver R/T
do I need front kevlar band they sell on ebay separately? anything else?
2001 Ram 2500 CTD
RD
Quote from: Thread_Marshal on August 04, 2005, 06:24:14 PM
on the 71 and up valve body's there are two springs on the side that provide pressure to the shafts.   one spring has a hex nut that you can adjust to increase or decrease pressure.   all you have to do is tighten it up in a clockwise motion and the spring pressure is increased.   the shaft then moves with a higher speed in between shifts and subsequently your shifts hit hard. enuff to bark the gears in a 1-2nd shift while in drive.   each time it shifts, the change in my holder rattles.   its rough, but i like it and wont change it for the world.
Silver R/T
i thinks thats what fastbackjon had done in his 67 by local trans shop. do you chirp tires?
2001 Ram 2500 CTD
RD
Quote from: Silver R/T on August 04, 2005, 07:40:15 PM
Quoteenuff to bark the gears in a 1-2nd shift while in drive
and thats with 15x10 295 series tires. goes a tide sideways at full throttle.  i like it alot!! vroom vroooooooom
Your B&M and the TF2 kits should both have included directions to raise line pressure.  You can overdo it too.
CFMopar
mine well chirp my 275/60/r15s if i get it just right. But I think It can be firmed up just a bit more. how can you tell the year on the tranny?
From the numbers stamped on the passenger side of the pan rail.  They may also be cast in on the bellhousing.
My photo album has info to identify the year of the transmission and there are pics of the two different line pressure adjusters (pic #80 & 81).
I agree with Runner, the cheapo "shift improver" kits are a waste of money; "tire chirping" is a very poor way to gauge transmission performance just like burnouts are a poor gauge of a car's overall performance. Reprogramming kits like the TransGo TF-2 and B&M Transpack address more of the issues that affect the transmission performance.
gsmopar
I've used the TransGo TF-2 and TF-3 with NO complaints.   Good product!
**edit**
Here's a link http://www.transgo.com/
sixty6charger
I know I'm reviving an old topic here but I just got a Transgo TF-2 kit and was wondering who here have installed it on their own or had a trans shop do it?
"...now bring me out those cheese sandwich appetizer you talked me out of."
I think several of us have.  Are you having a problem with it?
sixty6charger
Well, I'm not having a problem yet since I haven't tried to install it yet. But I would like some help or tips on what to look out for or make it go smoother. I don't know anything about trannies so it will be a learning experience. Just want it done correctly.
Duey
Quote from: sixty6charger on April 04, 2006, 12:26:55 PM
Did it myself...no probs...just keep track of how you took everything off, then carefully reverse it per TransGo's directions.  Clean workspace is ESSENTIAL!
Cheers,
Duey
What he said.  Surgical clean.
T16
What features does the TF-2 (for example) kit come with.. Just quicker shifts..?
Will it turn my 727 valve body into a manual one..?
The TF-2 kit retains all of the automatic functions but eliminates some of the slippage and overlap that is common in stock valve bodies, this makes the shifts firmer.
The TF-3 converts the valve body to full manual operation but retains the stock shift pattern. (Most aftermarket manual VB's reverse the pattern)
Joshua
Quote from: T16 on January 06, 2008, 03:03:36 PM
Hopefully later shifts.....TF's shift too early as it is. Firmer shifts are what ya want....
Before converting my car to a 4-speed, I was running a Turbo Action full manual, reverse pattern valve body, which provides VERY hard shifts, and ran on the street (and street raced) for many years with no problems, even though the box and instuctions say "Positively NOT for street use."..... :o ;D
Chargerguy74
My friend and his dad run a performance trans shop and only use TransGo. I was told the B&M were "garbage".
WANTED: NOS or excellent condition 72-74 4 speed shifter boot for bench or centre armrest car, part number 3467755. It's a rubber boot that looks like it's sewn up leather.
WANTED: My original 440 blocks. Serial # 2A188182 and 3A100002
hemihead
Quote from: Chryco Psycho on July 24, 2005, 12:59:31 AM
There was an article in a Mopar mag in the early 90's and I did my trans that way with no kit . Still works fantastic . Don't ask me what I did to it . I have brain damage and can't remember .
Lots of people talkin' , few of them know
Soul of a woman was created below
  Led Zeppelin
Dartbloke
Always use Trans Go Kits.
" The man that said nothing is impossible has never tried slamming a revolving door"
Bobs69
I've been told by a few guys to throw the accumulator spring over your shoulder and crank up the line preassure.  No kit needed????????
Bad idea.  First off, just tossing the accumulator spring and not blocking the piston will not make it shift any faster and can in fact, slow it down.  As for just cranking up line pressure, that can make it shift harder to a point but done indiscriminately with no other changes, it can create more problems than it solves.  Blown o-rings and seals come to mind.
Runner
Quote from: Chargerguy74 on January 30, 2008, 12:43:05 AM
  really depends on what b&m kit you get.  imo all the kits that are cheap are crap.  the b&m rebiuld kit is a really nice kit for a first time tranny biulder. great easy to follow instructions and decent parts.   for the person doing a shift kit wants some good instructions,  the tci kit is real nice .   i think you end up with something VERY simular to a tf2 kit, the instructions are much better though.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TCI%2D220000&N=700+4294908128+4294920458+115&autoview=sku
   i have 2 tf2 kits and one tci kit in my cars,  they all work about the same.
   the best shift kit ive ever installed in in a car was the one i put in my 68 plymouth last summer its a  np-a833 kit.  it really shifts firm   :icon_smile_big:
One thing about the TF-2 kit makes it a better bang for the buck and that's the improved manual valve which allows the converter to refill in Park.  This might seem like a minor issue but it's worth taking into considerastion when comparing kits and prices.
Best price I've found for the TF-2 is at Makco
http://www.bulkpart.com
Runner
i didint know that john. thanks.     thats good info.
Musicman
Duey
So why is it that a lot of guys bad mouth the TransGo kits?  I picked up a deep A-518 pan for my transmission at a tranny shop, and the guy rolled his eyes when I mentioned that I had a TF2 kit in my Torqflite...  :shruggy:
Cheers,
Duey
Was he a Ford guy?  I've never known anyone to bad talk the Trans-Go stuff.
Duey
No, he also had TH's and TF's as well.  I asked him what shift kit he'd recommend and he recommended no shift kit at all, said they weren't needed.  The engineer in me can't see how clutch packs working against each other to make a shift smoother for someone who wants their car to be as quiet and smooth as their living room couch to be a good thing?  ::)  Sure, the driveline has some more direct transient forces, but a shift kit clearly is easier on the transmission, lower temps, etc...
I'd be switching tranny shops.
oldkimmer
Quote from: Duey on March 28, 2008, 10:37:31 PM
Cheers,
Duey
.........Most ppl just assume u can just install this kit and it a done deal....not true.......Clearancing and attention to detail is where its at.......I have installed over 100 TF-2 kits......lots of trannys take some tweeking to get the shifts right on the money........I have redone so many that so called proffesional builders have done........There instructions r pretty good 4 some1 that has shift kit experiance, but 4 the novice builder  not up to snuff......kim.........any questions u can email me.........kimrudniski@sasktel.net
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
Kim, I'd add that everything you said is 100% true, but not just for an aftermarket kit.  All trans rebuilds should have the same attention to detail it's just that detail omissions become magnified in a situation like this.  That's why I say it's time to use a different builder, it sounds to me like that just wants to take the easy way out.
Duey
Quote from: Ghoste on March 29, 2008, 10:51:54 AM
Don't worry, I just got the A-518 pan there, I wouldn't take my car there.  ;)
Silver R/T
ive had it installed on my charger by a tranny shop when they rebuilt my 727
2001 Ram 2500 CTD
375instroke
