Rear Axle Gaskets
Started by 69fourspd, March 16, 2007, 03:09:24 PM
69fourspd
Cant seem to find this one... I have checked my service manual and it does not illustrate which way they go.
Which gaskets go on the rear housing first (8 3/4)?  Is it Steel Gasket>Drum Backing Plate>Foam>Axle  or  Foam>Drum Backing Plate>Steel Gasket>Axle
My memory isnt what it used to be.  It was only two months since I pulled the axles  ;)
foam  gasket   goes between the front of the back plate (in side the drum)  & the Axle shaft retainer.
69fourspd
Great.  Steel Gasket>Drum Backing Plate>Foam>Axle   Is what I was figuring on, but I thought I would check.  This site is a life saver  :2thumbs:
