3.91 Ring Gear
Started by Mopar Crazy, March 07, 2007, 03:41:15 PM
Mopar Crazy
Does anyone know the number of teeth a 3.91 Ring Gear would have????
The Ring Gear is a Richmond Gear.
Do it Once and Do it Right !!!
Ring gear has 43. Pinion has 11.
Mopar Crazy
Looks like I found a set of 3.91's.
74Charger
Now the question is do you know what case it goes in?   741?  742?  489?
74' Charger
03' 2500 4x4 CTD
Rolling_Thunder
can't you just get a caliper and measure the pinion stem diamiter ?
Quote from: Mopar Crazy on March 07, 2007, 04:48:30 PM
Don't go by the ring gear alone, 4.30 gears also used the 43 tooth ring gear. (43-10)
The same 43 tooth gear?
Mopar Crazy
I have a 489 case.  I called Richmond Gears. www.techsupport@richmondgear.com
I found a # on the Ring & Pinion, They said it was a 3.91 set.
FYI they were very helpfull...
Thanks for the replies...
