4 link system
Started by 68chargerboy, February 27, 2007, 01:45:16 PM
68chargerboy
i was wondering if anyone here can help me with directions or pictures as to how i can install this in my 66 monaco.  iknow this sit is for chargers, which you have all helped me with alot. but i was hoping to get some advice on this.   thanks in advance
                     Zach
it isd a complicated proceedure to install a 4 link system
you need to notch into the frame rails in front of the diff & install plates to cross pin the links in & they will have 3-4 adjustment holes for each link , generally the frame rails are replaced & moved inward at the same time to increase tire size , at the rear ther needs to be a new crossmember added to support the coil over shocks , these are adjustabe shocks with interchangable springs to adjust spring rate , often the gas tank will need to be moved or modified to add clearance for the shocks behind the diff , you will also need a panhard bar to locate the diff under the car & a braket on the frame for the bar
I would get a good suspension book & read up on all of the mods needed to make this work
68chargerboy
thanks alot for the info.   Zach
