Engine weight
Started by DrHemi, February 24, 2007, 04:50:35 PM
DrHemi
How much does a stock 383 weigh?
1938 Packard 120
1957 Studebaker Silver Hawk
1963 Ford Fairlane 500
1964 Ford Fairlane 500 (RIP due to code enforcement)
1970 Dodge Charger 500
1972 MG Midget
1987 Maserati BiTurbo Si
mikepmcs
In the 670 range???
v/r
Mike
DrHemi
So a 750lb engine stand will hold it
1938 Packard 120
1972 MG Midget
mikepmcs
Chatt69chgr
I wouldn't want to be bouncing the engine up and down any or you might exceed the 750 pound rating.  Seems like a lot of the engine stands I see advertised are 1000#.  I am referring to the ones that allow you to rotate the engine to work on it.
On a related subject, I went out looking for a roll around engine cradle.  I have an engine stand but the new 77 440 is going on it so my old 69 440 needs a new home.  I couldn't find one at Harbor Freight but did find one at Northern Tool.  Only cost $35 and it was rated for 1000#.  I have to make some adapter brackets so the engine mounts will bolt to it but I think it is going to work real good.  The wheels are cast iron with no rubber which is good too.
DrHemi
At the moment my engine stand is an old tire. But hey at least I'm working on the engine (about 4 months after i pulled it)
1938 Packard 120
1972 MG Midget
DrHemi
1938 Packard 120
1972 MG Midget
GTX
I wouldn't take this as gospel since I've seen slightly different numbers but should be very close. Your mileage may vary.
Make sure that you use in grade 8 bolts to mount. I always see people with hardware store specials (grade 5) holding their engine up.
Engine weights:
331/354 Hemi with alum. intake and water pump -504
392 Hemi with alum. intake and water pump ------ 564
Slant 6 ---------------------------------------------  525
273-340 ------------------------------------------- 525
360------------------------------------------------- 550
361-400 ------------------------------------------- 620
413-440 ------------------------------------------- 670
426 Street Hemi -----------------------------------765
