727 Tranny
Started by Bob, February 15, 2007, 10:15:32 AM
Bob
Ok, I set a record for myself. 4th post in one day. Anyway, my 727 will hesitate exactly 2 times. When I take it out for ride I get to the end of the driveway and when I attempt to go the rpm's will raise and then it kicks in. When I get to the end of my road (about a 1/4 mile) and try to enter the highway it does it one more time. After that, the rest of the day is fine. Any thoughts?
67_Dodge_Charger
Check your fluid level it might be low.  It sounds like your second gear band is slipping.
good luck
Robert
Bob
Thanks Robert but that was the first thing I did.
Band adjustment has nothing to do with initial takeoff.
My guess is that the seals in the rear clutch (needed for all forward gears) are hardened/shrunk and are leaking when cold. If seals are the problem an additive like Trans-X or Lucas will often help.
A pressure problem would also cause this so it would be wise to pull the pan and check for a clogged filter.
Bob
I guess I will pull the pan and service it before adding anything.
