Fuse Box Location
Started by snicker, February 09, 2007, 02:43:49 AM
snicker
Can someone post a picture of where the fuse box is supposed to be installed on a 69 Charger? Mine just hangs around loose under the dash :)
the fuse box is fitted behind this bracket, fixed with a large screw that passes through the bracket first . it is fitted so the word MOPAR is up side down.... have a look at your fuse box you'll see what i mean  :yesnod:
snicker
