Nice 451
Started by Challenger340, January 23, 2007, 12:16:36 AM
Challenger340
574 Horsepower/583 Ft/lbs Torque,  pump gas , 750 cfm carb, Torker 383 Intake, "all in" by 5700 rpm.
Will scan, and get the actual dyno sheets up later. This was a relatively inexpensive engine to build, and easy.  Whats better, is the Torque curve starts @ 3500 rpm at 542.3 Ft/lbs, and stays above 500 ft/lbs through 53-5400 rpm ? I forget already !
Enough to motivate ANY heavy "B" body.
Check it out, I'll get more photos and details up later.
http://www.dodgecharger.com/forum/index.php/topic,23089.0.html
Only wimps wear Bowties !
Challenger340
Dunno, what you'd spend, you'd have to talk to your builder 'bout that one, I'm sure he'd give you an estimate.
My Customer supplied some used EDDY heads, and a Torker 383 Intake, Thats it, That's ALL.
I supplied the rest, block, crank, Rods, Machining & balancing, etc.
Challenger340
I guess I should also get a "parts list" together, as to what was used in this engine ?
As well as the dyno sheets ?
Would this be helpful  ?
You fellas can price your own parts from where-ever, Machining, Porting & Balancing estimates from "your guys".
I've been posting photos of the Short Block, Crank, Heads etc., as a guide already.
Go here for a look if interested further;
451 short block prep used
http://www.dodgecharger.com/forum/index.php/topic,22274.0.html
or here, for the 451 EDDY head prep used
http://www.dodgecharger.com/forum/index.php/topic,21828.0.html
jg68
Gotta love them 451s, i had about 3500.00 in mine using stock 906s, according to the calculators, i was making around 530 FWHP, ran a best of 10.91 at 3100 lbs., 9.73 comp. XE284H, 750dp, bone stock 906s, shifting at 5800  ;)
Runner
what cam is in that motor? it sure runs good!
Challenger340
The Camshaft is our own "custom grind" from Comp. Cams. It is a Flat Tappet, solid lifter.
It is NOT proprietary, just a matching of lobe profiles from the existing Comp. databases, based upon our experience, building Mopar Race Engines over the last few decades.
It is NOT a fast ramp .904" lifter Diameter, and, It is EASY on springs and parts, as this is a "street" engine designed to live a long time.
I will supply the specs when I get time to scan, and post the dyno sheets etc.
It costs the SAME money to have a Cam ground, as buying one "off the shelf", the ONLY difference is the few dollars more freight, and about 2-3 week wait.
ANYBODY tells you different, WALK AWAY !
Bob out.
Quote from: Challenger340 on January 25, 2007, 12:05:21 PM
Bob out.
Yep, custom is the only way to go, especially when you have a dyno proven combo and years of experience like Bob has.  :icon_smile_big:
Ok Bob, quit slacking  :nana: :haha: and post those flow numbers, cam profile and dyno sheets !  :scope:
Challenger340
I'm working on it, will try for tomorrow.
Ron, check your pm and get back at me.
I bought a scanner. ANYBODY got a "quick lesson" I can reference on how to post, after I scan ? Posting from scanning ?
Other than that, I'll take photos and post, I got "that" figured out !  LOL !
Take picture
pictures in 'puter
Puter to host
Host attach to post.
Geez, I should have stayed in school !
Bob out.
mikepmcs
Bob
you have a PM.
v/r
Mike
as you know I'm thinking on make that stroke with JUST stock parts including torque converter ( 452 heads, 400 rods, stock camshaft, etc... ) trying to get an iron casted crank to keep same balancing and stuff around... that would be IF I find a crank locally. Of course only buying non stock the pistons. I want a complete sleeper. Maybe just mill down a little bit the heads and installing metalick gasket. Can I get something similar on HP and torque, and completelly streetable ?
jg68
Quote from: Nacho-RT74 on January 26, 2007, 10:42:51 AM
Nacho, i would use the 440 rods, this way you have a lighter piston, for the extra, you might as well get some good after market ones from 440source or Muscle Motors, i used a 69 crank & rods from a 440 for my 451 with the ross F/Ts, it didn't take much to balance out, but i got these parts on a trade, so i wasn't out much (just an intake) i spent about 250.00 to have the crank done (counterweights cut down & turned 10/10) for the money, you just can't beat the stroker kit, 1199.00 & you get crank, rods & pistons.
I have beeing searching a 440 crank for years and didn't find it... so I have to get it first. I have found complete 440 engines from friends, but I don't want to part out those.
if you think I'll spend $1200... think on international shipping ;) and I'll get double of that :P. plus machine job
mikepmcs
Ignacio
Just wait til your friend visits Connecticut again and have the kit delivered there and then your friend can bring it back.
v/r
Mike
