Gears
Started by terrible one, December 29, 2006, 06:34:37 PM
terrible one
Hey guys,
I was wondering what the easiest way was for finding out what gears I have in my rear end. Stampings? Factory chalk? What about some way of counting wheel rotations vs. input rotations?
Also, what gears were available for the 8 3/4 in '68?
mikepmcs
already a posted thread on here about this somewhere.  i'll try to find it.
v/r
Mike
terrible one
Thanks man. Sorry if this has already been discussed.
mikepmcs
TO
no, it's all good, i just can't think of how to do it right now, cause i'm well ahhh... it's friday night.
if you do not have sure grip leave 1 wheel on the grond & count the rotations of the driveshaft to get the 1 lifted tire to do 2 full rotations
if you haqve sure grip lift both tires & count the rotation of the driveshaft to get the tires to do 1 complete revolutuion
mikepmcs
squeakfinder
Or, if the third member is out of the car, divide wring gear tooth count by pinion gear tooth count.
For that matter, if it's out of the car, the ratio should be stamped into the side of the ring gear someplace.
terrible one
I appreciate the help everyone. The third member is not out of the car or anything, and it's not a suregrip unit, so I'll go for the one wheel on the ground and counting rotations process here in a little while.
mikepmcs
keep us posted, i'm curious to know.  My guess is 2.7's.   and don't forget to look for a tag on the center chunk on one of the bolts too, it might still be there.
i'll look for the gear info for you let me do some pokin around.
here's a link to moparts page in the mean time.  great info and some real cool education on rear ends.  i learned alot
http://www.moparts.com/Tech/Archive/axle.html
v/r
Mike
terrible one
Well, as I (and mikepmcs) expected, I'm quite certain I have 2.73's. With two turns on one wheel while the other was on the ground, the input turned a little over 2.5 times.
Furthermore, there is what I would consider more play than normal between the input and the axle shafts. I can move the wheel forward and back a bit without the input moving...lots of slack.
Anyways, my back brakes are shot, and it seems as if the third member has seen better days. I was planning on pulling the rear to replace the leaf springs, shocks, and brake parts, plus to clean up the gears and all. But with these high gears I would like to swap them out for something lower, like some 3.55 or 3.91's...
mikepmcs
Hey you made it to old timer, congratulations.   :icon_smile_big:
i'll just take a stab on the 68 gear availability and i'm sure if i'm wrong someone will correct me.
2.73, i think there might be a 2.9 one. 3.23, 3.55, 3.73, 3.91, 4.10.
I actually just stuffed a 3.23 sure grip in there from my 2.7 one legger and I notice a little difference.  I was hoping to score a 3.55 chunk and that would have been primo for me but the price was right so i went for it.  I'm not going to experiment with setting up a rear at this point but if i find another 489 case for cheap i might go for it.  here's a great read on how to set up a rear end. not on my top priority list right now though.
http://www.moparmusclemagazine.com/howto/155_0308_mopar_rear_end_gears_set_up/
3.55 should be all you need but if you want more punch out the hole 3.7 or 3.9 would be even better obviously.  depends on what you are going for.  I know Dodge Freak is real happy with 3.9's in the rear and he drives it all the time.  I just thought 3.5 would give me the best bang for my application.
v/r
Mike
terrible one
Yeah, I guess I'll see how things play out. Maybe once I pull the rear and inspect the current gears, etc. I can go from there. I would really love to have a lower geared suregrip chunk to put in there but they're getting pretty high. We'll see.
mikepmcs
as you know, they are on ebay, i got mine for $200 bucks, because the guy made a mistake in the ad and noone would bid on it.  I looked at the picture and it was obviously a SG rear but he had open differential in the ad.  I emailed him and asked/told him this so he could update his ad but by the time he did it the auction was almost over and i'm the only one who bid on it.
I guess the reason i say this is type in obscure stuff when you look for the chunk.  there are so many different ways to say mopar 8-3/4, 8/75, 83/4  dodge rear, etc.... you get the idea.  another thing is a lot of these guys on there call it posi!  so type in mopar posi, dodge posi, etc....
you'll be surprised on what you come up with and be patient it will come around.
:icon_smile_big:
v/r
Mike
terrible one
Yeah, I'll keep my eyes open. What is the visible difference between a suregrip and open unit?
Also, how expensive are aftermarket gears for my current third member? I know it would still be open, but maybe that would be the best way to go?
mikepmcs
TO,
if you want to go that route there is 2 or more 3.55 open diff's on ebay right now for $50+
one's in pieces and one is complete.  the second ad i'm linking you to has a great picture of an open differential rear and it has the much desired 489 case..  SG are cone and clutch , and I believe the clutch type is more desired as to the ease of rebuilding parts available for this type SG unit.  I'll get you the link to the explanation of sure grip units and try to find you a picture of both types(cone and clutch)
http://cgi.ebay.com/ebaymotors/mopar-dodge-8-3-4-8-75-741-complete-3-55_W0QQcmdZViewItemQQcategoryZ33731QQihZ009QQitemZ190065689762QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/mopar-8-3-4-3-55-489-large-yoke_W0QQcmdZViewItemQQcategoryZ42606QQihZ015QQitemZ250068560832QQrdZ1QQsspagenameZWDVW
to answer your question on ring and pinion prices, they are pricey brand new, then setup cost and so on.  If it were me, i'd piece some old stuff together like,score a sg unit somewhere, a case with gears already in it.  this is the much cheaper way to go.
UPDATE.... here you go, an excellent explanation of the SG units with pictures.
http://www.moparts.com/Tech/Archive/axle/13.html
v/r
Mike
Bandit72
Quote from: terrible one on December 31, 2006, 02:33:17 PM
keep an eye on old dodge trucks, (61-71) most of them had 8 3/4 rears with usually 3.5 gears, some sure grip some not, if you can find an ex government or military truck, almost all of them had sure grips, i got lucky and found an ex military 62 with a 3.91 sure grip, scored teh whole truck for $150 bucks  :icon_smile_tongue:
Daddy ran whiskey in a big black dodge
bought it at an auction at the masons lodge,
Johnson County Sherriff painted on the side,
just shot a coat of primer then he looked inside,
well him and my uncle tore that engine down,
I still remember that rumblin' sound.....
terrible one
I might look into one of those 3.55 open units currently on Ebay, but I'm not going to rush. I still think there is hope for a good deal on a suregrip unit.
Thanks for all of the help everyone!
terrible one
Furthermore, if I ordered a 3.91, or 43-11 ring and pinion, and switched them out for my old ones, would that be all that I need to be good to go with my current chunk?
you need to get gears for the specific carrier you have & I would install new brgs while you have it apart
you May need a different yolk as well depending what spline the pinions [new & old ] are
terrible one
Quote from: Chryco Psycho on January 01, 2007, 04:25:20 PM
Do you know how much gears and bearings would run me? I figure it might be easier just to buy a new ring and pinion and then bearings because the price of a new chunk plus shipping would be a killer. Those things must weigh like 80 pounds. It still wouldn't be a suregrip but at least I could have the gear combo I have and put them in while I already have it apart.
mikepmcs
IMHO, you can get a chunk with a desired gear ratio(maybe open carrier) for less than it would cost to put together a new set.
my.02
d72hemi
are the sure grip units 8 3/4 only, or did they come in other rearends (dana 60?) also?
mikepmcs
Quote from: d72hemi on January 01, 2007, 08:05:43 PM
No, yes, and yes.  believe it was called power lock in the 60.
http://www.autohobbydigest.com/dana.html
the gears & brgs generally run 300-400 + the labor to set them up
powr lock in the 60s & lighter units in the 70s were Track locks / Crack locks
terrible one
Well I suppose I'll just have to find a good deal on a lower-geared chunk from Ebay. I doubt I'll be able to get ahold of a suregrip for the kind of money I'm wanting to spend, but surely I can get something better than my tired 2.73 combo.
d72hemi
Cool, so Terrible One and I could get a  Power Lock or Track Lock out of a Dana and use it in a 8 3/4 setup. Hopfully Terrible One is like me where Dana's are all over the place (UT). I will have to start pricing danas with lockers when I get home!
mikepmcs
Quote from: d72hemi on January 02, 2007, 01:29:08 PM
Wait, i don't think that is the case and i didn't mean to imply that.  I really don't know that answer.  But if you can get a dana rear(drum to drum) for cheap why not fab that one in there.
v/r
Mike
d72hemi
I was thinking of that also. One of the Mopar mags did an artical on improving the 8 3/4. one of the thing they did was use (I think) 80s pherd truck berrings (I think because they are self contained) by welding on aftermarket ends. They also used those trick "worm gear" limited slip units, but that is outside of mu budget, for now. I don't see why a similar thing could be done to a Dana 60? TO, sorry if  I am hijacking.
terrible one
d72hemi, no worries man. I wouldn't call it a hijack at all
Unfortunately, I don't have much of a supply of anything around here scrapyard wise. There's nothing within miles that isn't packed with only 80's and up type stuff. I'm sure what I'll end up doing is just getting a higher geared open chunk. I'll search around here first of course so that I don't get bit in the ass by shipping fees!
d72hemi
If you find something that needs to be shipped, but less than 100 lbs, like a disisembles 8 3/4 rearend, you could have it sent via Grey Hound bus. It can take a day or two longer, but it is cheep! I would not send anything that could break, like a set id 71 tail lights, with a bumper  :flame: .  Other than that I have had good luck with Grey Hound. I will try to hit the junk yard when I get home in March or April, to look for parts, so let me know if you are still looking for a rearend. Most of the yard owners know me, so I get ok deals.
Ian
terrible one
Yeah, the Greyhound thing sounds nice besides the fact that the nearest station is 2 hours away from me.  :rotz:
I appreciate the offer and I'll keep in touch as well as check around down here.
