Nitrous Oxide?
Started by Arkgl01, November 20, 2006, 03:41:22 PM
Arkgl01
I want to put a nice Nitrous Oxide kit on my 440. Dont want anything madjor just a 100 shot for the drag strip. What is a good safe kit and what would you recommend?
Mark
69 440 RT matching.. mostly original!
68chargerboy
the best nitrous setup is non at all.  if you want more power put in a stroker kit or something in that nature.  i have first hand seen a piston rod go through a block.  in my mind its not worth the risk.
                                        Zach
make SURE you have adequate fuel supply running lean will take out an engine so fast !!!
73chargercali
i'm running edelbrocks performer rpm nitrous kit its adjustable from 100-250 hp levels. i personally belive its the best packaged deal, i only paid approx $450 for it and it makes great horsepower levels. it knocked 2.5 seconds off my quarter mile time putting me in the high 13's. i'm running a unrebuilt 440 with a eddy 440 torker intake and eddy 750 cfm carb, all in a 4000 pound car. the kit was easy to install in 5 hours.
just undershoot the power level; if you are sure the car can take 150 shot, just use the 100hp setting. on stock cast pistons it causes lots of fatigue and on cast cranks it can cause problems.
i would only recommend nitrous if your engine is a forged piston, forged crank setup, with a good enough transmission. just remember only spray from 2000rpm and higher, any less and you can blow off your intake.
Arkgl01
Planning on just a 50 shot and see how the motor does. I will have it where you must be full throttle to hit it. I really want it for looks and a cool purge kit.
Steve P.
Quote from: Arkgl01 on December 01, 2006, 11:07:11 AM
What's next, a pair of fart cans??    :icon_smile_big:
Steve P.
Holiday, Florida
TylerCharger69
Just my 2 cents....but...why should a Mopar need nitrous anyway?  Stroke it!!
konigcharger
leave the nitrous for the cars that really need it
honda's ;)
If you have no vision or creative spirit, you can always fall back on the way the factory did it.
Silver R/T
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
Wakko
Pull that silly 440 and put in a Skyline motor!
Ian
'69 Basketcase, bluetooth powered
Boynton 236 F&AM
moparguy01
nitrous can be a fun addition to your car, but you gotta make damn sure you have adequate fuel, and high enough octane fuel. if not, BOOM!
i ran a 100 HP NOS kit in my 85 mercury grand marquis back in high school. and it didnt hurt it, that was a mildly built 302.
i wouldnt run over a 100 HP shot if you dont have a dedicated nitrous fuel system (seperate pump and line to the engine from a secondary fuel tank) and I would also want forged pistons, forged crank, etc if i was running more than that. Which is exactly whats in my 440. :devil:
THE CHARGER PUNK
isnt your car a real general lee?
Challenger340
Anybody wanna see pictures of what a 1600 hp, Nitrous 632 Chebby, looks like internally, when it goes "lean" on the "steroids" ?
tehehehe !
I think it's a "hoot', cause I gets paid to fix it !
Frigg'in 'roids !
Only wimps wear Bowties !
Arkgl01
Yes it is. I am doing it mostly for show. It can always be pulled off. http://www.scotleaidolrods.com/originalgl1.htm
Lostsheep
You know.....just follow the directions on the spray and you should be fine. I would recommend an NX kit, and make sure your fuel pressure is adequate, plus have an aftermarket ignition source. I wouldn't recommend the WOT switch, make it a manual switch you gotta push. I've had several street cars with over a 200 shot and they did great!!! Colder plugs, great spark, retarded timing, forged parts and a good kit you'll be flyin in no time.
Mefirst
Lostsheep***
Why would you not recommend a WOT switch for Nitrous use? The reason you do use one is that you wont accidentally push the Nitrous button when your engine turning low rews. Squirting Nitrous into an engine at low rews is a good way to have an engine go BOOM!! Nitrous is to be used only at high rews.
Another thing is that when using a WOT switch, you wont have to fiddle around pushing any buttons, you can concentrate on driving and keeping your eyes on the track/street. Then again I do understand using a push button, if you have a 2 Stage Nitrous system, the push button activates the 2;nd stage, but you still use a WOT switch that is the only switch to activate the Nitrous system...
My :Twocents:
Lostsheep
Well my thing with the WOT switches on a single stage system is its a bit unpredictable on the street. I have seen more than a few guys pop their intakes off with WOT switches. But if you start spinning on the bottle how do you stop?.....by quickly pulling your foot of the gas and nitrous giving the gases no where to go, I know its not a serious as a top fuel car but thats my best comparison to when they hydraulic a motor from pedaling it. With a hand held switch you can start spinning and come off the button till you hook again all the time maintain full throttle. I know with the duel stage kits you kinna have to have at least one on a WOT. But the WOT switch can get engaged at just as low of and RPM as a hand held switch. Just preference/my experiences I guess.
hutch
I always hear that NOS and Superchargers will cause you to rebuild your engine every so many times you use them.  They burn out your valves, rings, pistons, ect... Is any of this true or all just myth?  Can you have one on your car and setup where it gives you a kick but does not hurt your motor?  I went with just a cold air kit and felt good about what it gave me but now I think I want more.
it took me 30 min to type this.
:devil:
In the words of Colonel Sanders,,,   "I'm too drunk,,, to taste this chicken"
Lostsheep
Well there is truth to it, but its all in how its used. If your always pushing the motor then its gonna wear out more quickly. Turbos, superchargers, and NOS due add a great deal more cylinder pressure, but thats what makes power and them very useful.
deputycrawford
All throttle, No bottle. 512 cubes solves many things.
If it ain't wide open; it ain't running.        Rule number one in motocross racing: Pin it; row the gear box; and wait until you hit something.     At work my motto is: If you need me, call someone else.
Lostsheep
Im a run whatcha brung kind of guy....If you brought more, you win. ;)
rob9593
Quote from: deputycrawford on March 15, 2007, 07:11:09 PM
Nothing wrong with both....I'm going to be running a 505 stroker, and touch it with the bottle occasionally.... whether I'll ever hook up that much power is another question.... my 505 made 700HP on a stingy dyno naturally aspirated on 91 pump gas...
I'll be using a WOT throttle switch along with a manual switch to engage the system......it'll be used very sparingly as insurance just to make sure I've most likely brought more than the next guy in the other lane
aifilaw
Quote from: hutch on February 28, 2007, 01:35:24 PM
:devil:
since no one else has properly answered this question....
Nitrous, just like other power adders adds wear and tear to your engine, just like a cam change, headers, intake, et cetera do...it just adds more, faster, for less work, and less money.
Depending on how you build your baseline (in this case bottom end), or how it is stock, will depend on what you can do to it and how long it will run afterwards.
People who burn out valves, melt pistons, et cetera do things like run too high of a shot of nitrous in a car that isn't meant too...they slap a 150 dry kit onto a 350 chevy and expect it to last forever, what they get is a rude awakening on their 10th pull.
People who have nitrous in their minds when they build their engine have no problems, or those who run a realistic level... for example, there are guys in STOCK LT1's and LS1's who run a 100 we shot and have put dozens of bottles through their cars, have over 100k miles and virtually no wear...why? because they do it right. You can do the same thing on any engine, just keep things realistic, ensure that your timing is retarded when running nitrous to take full effect of its power adding, and ensure that you have certain fuel flow for the nitrous...that's why wet kits and nitrous nannies are the best thing to have, they may cost more, but they are worth it.
That being said, a 440 stock block with stock everything should have no problem running a 100 shot all day every day as long as you tune it correctly. put in forged pistons, hardened valve seats, good valves, steel crank, decent rods, and you should have absolutely not problem running a 200+ shot of nitrous all day at the track for more than a season, or pass a dozen bottles through it as a daily driver with no wear and tear to your engine.
People who don't like nitrous, and profess cubes, have their own opinion...if you like having power there all the time, go for it. Some people like poweron demand, and others like to be able to turn it on and off....it's nice getting 5mpg better and making the same HP and TQ 90% of the driving you do by running nitrous instead of forced induction or large cubes.
'72 B5 Metallic Blue Hardtop
Bandit4142
Quote from: aifilaw on March 28, 2007, 09:39:12 PM
:devil:
People who have nitrous in their minds when they build their engine have no problems, or those who run a realistic level... for example, there are guys in STOCK LT1's and LS1's who run a 100 we shot and have put dozens of bottles through their cars, have over 100k miles and virtually no wear...why? because they do it right. You can do the same thing on any engine, just keep things realistic, ensure that your timing is advanced when running nitrous to take full effect of its power adding, and ensure that you have certain fuel flow for the nitrous...that's why wet kits and nitrous nannies are the best thing to have, they may cost more, but they are worth it.
Very, very well put.    :iagree:
1969 Charger - 383 mag auto - Sold and sorely missed.
1970 Charger R/T - 440 mag - sold
1969 Super Bee - 383 mag auto - sold
1969 Cornet R/T - 383 mag 4 spd - sold
Lostsheep
Too bad you wanna retard timing for nitrous use.
