Won't go into reverse!
Started by Timbo, November 04, 2006, 07:03:32 AM
Timbo
Morning Guys
Last week I was moving her off the drive.   She went into reverse okay - then forward okay - I was a little heavy on the brakes and jolted to a stop - and then she wouldn't go into reverse - it was as if she was in neutral.  I checked under the car and found the three wires that go into the transmission just hanging down - no sign of the connector.
I fitted a new connector this morning and the problem remains - She's fine in Drive; 1 and 2, but reverse is like neutral.
I had the transmission rebuilt a couple of years ago - so what's the problem - is it the transmission or the wiring?  Help?
Advice gratefully received.
Cheers, Tim
The head nurse spoke up, said "Leave this one alone!"
1970 440 R/T
oldkimmer
First ..check to verify proper fluid level....in neutral............ If it drives ok in 1,2+3 u have a broken rear band and or strut,or the seal on the rear pistion blew. Also if the seal in the front drum blew=no reverse+no 3rd gear.............This is on a 727 or 904 auto.
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
wiring running up to tranny has nothing to do with mechanical job. Wiring is just signals to send ground to starter relay and start on back up lamps.
I'm agree with oldkimmer
Timbo
Thanks guys - looks like a visit to a transmission specialist is on order.  More expense!
Cheers, Tim
1970 440 R/T
It's worth the effort to pull the pan, like ok said it might be a band strut or seal that can be fixed without major disassembly or expenditure.
Timbo
Thanks John - I'll keep my fingers crossed it's not a big job - but I always fear the worst!
Cheers, Tim
1970 440 R/T
