HELP NEED FITTING
Started by moparjohn, September 21, 2006, 08:12:55 PM
moparjohn
OK, one small problem B/4 I get the car back on the road.  I stripped the power steering fitting that is screwed into the steering box and then recieves the power steering high pressure line. Who has or knows where you can get this fitting. 3 cars in the "yard" had differnt fittings that would not work.  69 Charger P/S fed. pump I belive. John
Happiness is having a hole in your roof!
resq302
John,
Is that the double male threaded part that goes into the valve body?  If so, you might want to try a shop that makes hydraulic lines for fork lifts, snow plows, etc.
Brian
