wont start...
Started by Silver R/T, August 23, 2005, 01:36:02 PM
Silver R/T
tried to fire up my R/T yesterday, but it just wouldnt start, battery got enough juice, got fuel, kept cranking but it just wouldnt start. Never happened before ::)
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
KMPX2
Silver R/T
I noticed that when I hook up battery when I usually hook up last cable (positive after negative) it gives mini spark which is normal in this case it doesnt give that mini spark. And after cranking and then disconnecting battery again battery cable contacts/clamps felt warm. What this might be?
2001 Ram 2500 CTD
It's drawing a high load someplace.  When it's cranking does it sound like it's trying to start but as soon as you let the key off to the run position, it dies?
Plumcrazy
Pull the coil wire out of the dist and hold it about a 1/4 inch from a good ground with a pair of insulated pliers.  Crank it over and see if you have spark.
Silver R/T
magically started today
2001 Ram 2500 CTD
Charger4404spd
......and sounds like it will leave you magically stranded on the roadside soon! Weird.
Plumcrazy
Quote from: Charger4404spd on September 01, 2005, 05:18:57 AM
At the most inconvenient time too.  :icon_smile_sad:
Silver R/T
i think something happened to neutral ps cause its not hooked up right to trans but to negative cable terminal, probably made bad contact last time this time started right up with my mallory
2001 Ram 2500 CTD
73chgrSE
Quote from: Ghoste on August 26, 2005, 03:12:44 PM
What would that mean if it does?
moparguy01
I would check all the battery cable connections as well as any starter connections. see if anything is loose. I've seen stranger things happen.
Quote from: 73chgrSE on March 28, 2007, 01:54:41 PM
Mostly Ignition switch damaged, or loosen wires down the column ( blue line ) or bulkhead conector.
LargerCharger383
mine did the exact same thing at the beginning of the year and it was the wire going from the coil+ to a small white box (resistor i think?) on the firewall. replaced the wire and it's fine.
mikepmcs
This white box?
71ChallengeHer
Quote from: mikepmcs on April 03, 2007, 10:38:29 PM
This white box?
It's always a good idea to carry a spare resistor with you. ;)
konigcharger
:iagree: i always carry a spare, the have a tendency to break at the worst times
If you have no vision or creative spirit, you can always fall back on the way the factory did it.
