Torque Specs
Started by Mopar Crazy, August 19, 2006, 07:28:39 PM
Mopar Crazy
Does anyone have torque spec's for front ends parts. i.e. Ball Joints, Tie Rods, etc????? ???
Pete
Do it Once and Do it Right !!!
I assume it's for the Charger.
Ball joint-upper... 125
Nut-lower... 100
     -upper... 100
Control arm-pivot shaft nut... 130
                -rebound bumpers... 200 inch pounds
K frame bolts... 150
Idler arm stud nuts-at center link... 40
                          -at mounting bracket... 65
Shock absorber nuts-lower... 50
                            -upper... 25
Steering gear mounting bolts... 80
Steering knuckle bolt nuts-lower... 120
                                    -disc brakes... 100
                                    -upper... 55
Strut nuts-front... 50
              -rear... 100
Sway bar-link insulator...100 inch pounds
             -link to frame... 100 inch pounds
Tie rod ends-sleeve clamp nut... 115 inch pounds
                  -stud nuts... 40
Wheel nuts... 65
Mopar Crazy
Thanks Ghoste...   Yes, it's the Charger. Finally getting some time for her.
This is some great info.  More then I expected.
:cheers:
Steve P.
I think they ALL get that German torque spec. : NIZENTIGHT..... :devil:
Steve P.
Holiday, Florida
