rear u bolts
Started by darkside, August 16, 2006, 01:52:25 PM
darkside
I need a set of new u bolts for my 69 charger the rear end  is 8 3/4,What size u bolts come from factory?
deputycrawford
Check with manciniracing.com and they can tell you. Ron Mancini has raced Mopars for years and is well known in the industry. He sells all the parts and can steer you in the right direction.
If it ain't wide open; it ain't running.        Rule number one in motocross racing: Pin it; row the gear box; and wait until you hit something.     At work my motto is: If you need me, call someone else.
depending on the spring thickness most came with 1/2 bolts 7" long with 3" inner bend over the axle
darkside
