nfs-no f###ing spark
Started by andy74, July 30, 2006, 08:31:49 PM
andy74
my charger was running great,and then it comes down to this,i had a sputter at 3000 and up rpms,which lasted for a day or 2, then after i drove it today,it wouldnt start-no spark at all,i changed the igntion box,coil and ballast last night trying to cure the sputter,and after driving a few miles it wont start or spark at all-dist is less thana  year old and i put new plugs and wires on a month ago-any ideas or how to check?
dodge freak
You can take a ohm meter and check the resistance of the pick up coil leads from the dist, think it should be around 280 but not sure, sorry. 1 year old should be ok but and if your vacuum advance is working-hook up-sometimes the wire or wires get damaged. If you have the Mopar box and its got 5 pins you should get 12 volts at the #1 pin, thats the middle one of the three and #3 should have some volts not sure how much cause its coming off the ballet resistor, thats the one of the 2 either on top or bottom , the other one is from the pick up dist. lead.
Have no picture of this digram that I have, sounds like a bad pick up coil in the dist or a wiring problem. I have msd so I can not check mine and tell you what I have.
dodge freak
 I could draw it out for you but I don't know how to post it.
Quote from: dodge freak on July 30, 2006, 09:40:18 PM
:iagree:
I have had several times just loosen Rubber dist pick up coil plug, and also ECU module plug itself
4 and 5 are leads to dist pick up
3 is low voltage resistor source...I never tested and Haynes manual only talks about ohm directly at ballast
Todd Wilson
Hows your ground to the ECU box? Take a test lead and clip it to the ECU and ground and see what you got. Otherwise that tells me its a wiring problem under the hood ignition area or the reluctor could be bad or out of adjustment.
Being a new distributor youi would think that would not be the case but it seems the quality of parts anymore isnt very good and if its a remanufactured dist. you got then it very well could be that as they use the cheapest parts and labor to reman. something and usually ends up poor quality. An exchange is cheaper then paying $ for good parts and labor. We got to show profits for CEO's to get bonus's!
Todd
Andy, check the voltage going in/out of the ballist.
andy74
Quote from: firefighter3931 on July 31, 2006, 01:37:38 PM
i am having her towed to the shop,we can figure it out there,as i am tired of messing around in the gas station parking lot where she quit,plus i can get to the beers way to easily if i am near a convienece store!!
I bet will be the plugs :D. The cheaper parts and more sensitive to engine heat and dust. Is my experience ;)
andy74
well, after some hair pulling, i found that the bolts on the ignition box were loose,and i had a burned plug wire,both at the same time im sure was a coincedence-the burnt wire caused my skip,and the backed out bolts were causing my no spark-they were just loose enough where they appeared tight,so i pulled the tapping screws out,and used 2 bolts with nuts and lock washers-should be good now! i just got back from a full throtle run her to red line in first and second blast down the high way,and she seems fine!
Good to hear it's all fixed up Andy.  :yesnod: Bad ground and defective wire  :P It's allways the simple stuff huh  :-\
andy74
okay, the freaking thing wouldnt start this morning again,what the hell did i do to deserve this?
Runner
check you bulkhead conector
Quote from: Nacho-RT74 on July 31, 2006, 12:45:39 AM
:iagree:
Beside stated above, then check:
-12 Volts at blue wire on ballast on RUN position.
-12 Volts at brown wire at START position ( positive lead of coil )
-Around 8-10 Volts at brown wire at RUN position ( positive lead of coil )
-12 Volts at cavity 1 of ECU at Run position.
If starter motor cranks, that's all you need to check where is the fail.
andy74
there was a wire cracked in the harness to the starter relay,so i replaced it and checked the others for problems,so the starting issue is solved!
Oh Ok then engine not even cranked with starter!!! I thought was cranking, that's why I never post about check starter wires.
andy74
Quote from: Nacho-RT74 on August 11, 2006, 09:19:13 AM
she was cranking,just no spark-the starter cable i replaced just because i had one,and it looked kind of crappy,the spark issue was the wiring grounding out on the intake,damn thing! on a different note, i melted the shifter cable after all that work yesterday!!
Silver R/T
Quote from: andy74 on August 09, 2006, 10:46:13 AM
maybe cause youre asshole...hmm DING DING DING..
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
I thought getting threads locked was only a pastime in the off topic area. ::)
andy74
Quote from: Ghoste on August 25, 2006, 03:55:00 AM
i always consider the source,and seems like spouting bull shit is all one individual here is good for-i dont recall ever seeing one useful thing from the dumb MF,but that could be me
dodge freak
This place is like driving on the freeway-Theres a bunch of fun cool people here and theres always a few jerks on the road also. Theres even cops on here too-" lock topics" come to mind.
andy74
Quote from: dodge freak on August 26, 2006, 11:30:34 AM
that is a very good way of putting it dodge freak!
Steve P.
Damn, Silver,,, that certainly WAS NOT called for!!!!! :rotz:
Steve P.
Holiday, Florida
Brock Samson
don't worry,..  I'm sure when he hits 4k he'll stop.  :icon_smile_big:
andy74
Quote from: Steve P. on August 28, 2006, 11:20:36 AM
just showing what a dick he is,no big deal
Plumcrazy
