HELP ME!!!!!!!!!
Started by johnyACOSTA, August 19, 2005, 09:55:29 AM
johnyACOSTA
AL MOTOR NO LE LLEGA ACEITE A LOS TAPA VALVULAS!!!!!  :o ALGUIEN ME PUEDE AYUDAR??????  ??? ??? ??? ???
:icon_smile_question: :icon_smile_question: :icon_smile_question: YA YA REVISE LA BOMBA DE ACEITE Y ESTA BUENA!!!!
The motor valve does not raise to him to the oil until the cover, I
already reviewed the oil pump and this perfect one.  ??? ??? ??? ??? and have an extrange sound
PocketThunder
i wish i would have paid attention in spanish class.... :-\
"Liberalism is a disease that attacks one's ability to understand logic. Extreme manifestations include the willingness to continue down a path of self destruction, based solely on a delusional belief in a failed ideology."
MGBRingo
I can read the little yellow faces but that is about it.    :P
Telvis
Whatever he's saying it must really be important. He seems pretty excited. I hope doesn't need the Police of an ambulance. All those capital letters and exclamation points. I hope he hasn't fallen into a well with only a laptop and can't get out. :icon_smile_big:
ying
damn it troy where is the SAP button!!!!!!!!!!!!!!!!!!!!
1968 Charger R/T
440 auto
Purple w/silver stripes
3:91
slotted mags
johnyACOSTA
Quote from: PocketThunder on August 19, 2005, 10:13:46 AM
johnyACOSTA
Quote from: MGBRingo on August 19, 2005, 10:22:25 AM
johnyACOSTA
Quote from: Telvis on August 19, 2005, 10:27:42 AM
ying
so you are not getting oil to the top of your engine? good oil pump!
1968 Charger R/T
440 auto
3:91
slotted mags
Telvis
ying
clogged filter?         oil pump shaft broken? look at these two places
1968 Charger R/T
440 auto
3:91
slotted mags
ChargerRob
What johnyACOSTA is trying to say is: Oil is not getting to the valve tappets/Hydrualic lifters. Can somebody please help with advice. I checked the oil pump and it's working fine.
Mighty Mean Mexican Mopar
IBsmokin
hey is there an echo in here???
CB
1968 Dodge Coronet 500
41husk
Johnny, might want to post in the tech area, more answers, less commedians.  Adios, amigo!
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
Old Moparz
Quote from: 41husk on August 19, 2005, 01:01:39 PM
True, but you'll never find Mojo in there & he speaks Spanish.  :icon_smile_big:
               Bob
              Going Nowhere In A Hurry
LOL...
he is a buddy's mine here in Venezuela and I don't really know where is the problem. ChargerRob got the perfect translation, even he already said oil is not getting up to valve covers.
Ponch ®
Quote from: ChargerRob on August 19, 2005, 12:15:19 PM
:yesnod:  :thumbs:
"I spent most of my money on cars, birds, and booze. The rest I squandered." - George Best
Chrysler Performance West
ChargerRob
Quote from: IBsmokin on August 19, 2005, 12:22:59 PM
Damn IBSmokin, I was only trying to help by translating. :cryin: But that's cool, I'm not thin skinned.   8)
johnyACOSTA
Quote from: ying on August 19, 2005, 12:13:12 PM
thanks, but no clogged filter and the oil pump shaft is very good..... somebody more???????????
johnyACOSTA
Quote from: ChargerRob on August 19, 2005, 02:16:09 PM
thanks!!!!!!  :icon_smile_cool:
Daytona R/T SE
Cam bearing has turned in it's bore, cutting off the oil flow to the rocker arms...no hablo espanol...spanish class was right after lunch...we almost always smoked our lunch   :apimp: :smoke:
MTPOCKET
IBsmokin
KMPX2
Is this a new motor , old motor, was any work just done to it . More details needed.
johnyACOSTA
Quote from: KMPX2 on August 20, 2005, 12:20:06 AM
this motor have 4 years of refubrished
KMPX2
OK if this motor has been running for 4 years when was the last time you changed the oil filter? Even if the car has sat for the last 4 years things go bad from just sitting. There is a old saying K.I.S.S.( Keep It Simple Stupid ) most guys will make a problem harder than it needs to be. No oil did you change the filter? I don't care if you put on on last week something may have happened to it , Put a new one on it and see what happens. What does the oil look like? If you changed it last week and it looked like mud you could be plugged up some place.
johnyACOSTA
Quote from: KMPX2 on August 20, 2005, 11:25:12 AM
I did change the oil filter and the oil motor, always i change the oil motor before 5.000 Km... the oil looks transparent... thanks
Quote from: Daytona R/T SE on August 19, 2005, 03:22:30 PM
Quote
I agree the cam brg is the most likely problem
Rocky
I know this may be a simple question, but are you checking the pressure with the engine running, or just by priming the pump.  I like to start with the K.I.S.S.
Quote from: Chryco Psycho on August 22, 2005, 01:43:32 AM
Quote
Johny... creo que esto es lo que podria ser, las bocinas de el arbol de levas giraron y bloquearon el paso de aceite hacia arriba.
Para chequear eso, tendrias que desarmar las camaras ( sin desmontar las camaras ), quiero decir, quitar los martillos, para quitar luego los taquetes. Desarmar el frente del motor ( bomba de agua, compresor de aire, alternador, damper tapacadena, cadena de los tiempos, radiador ) para sacar el arbol de levas y revisar las bocinas a ver si estan movidas dentro del bloque.
ChgrSteve67
I would suspect spun a cam bearing.
Did this engine overheat or just begin making a sound one day?
I think either way the motor should be taken apart and examined completely.
If you keep messing with it and taking guesses your solution will be an engine replacement.
cudaken
 Nacho, ask him why he thinks he lost oil pressuer. Did the engine start to rattel?
                           Cuda Ken
I am back
