wheel and tire combo
Started by Charger500, July 22, 2006, 04:48:33 PM
Charger500
Hello,
I am ready to purchase my wheels and tires. I am going to get the TT II's 15x8 in the rear 15x7 up front with BF Goodrich radial T/A 275-60x15 in the rear and 245-60x15 up front. I went to costco seeing if they will be able to put everything on etc...and they were trying to tell me that they won't fit. I know a lot of people run this same combo or something pretty close to it. I just wanted to make sure that this will fit on my 70' charger and that I don't have to make any modifications or anything. Thanks!
Charger500
P.S. I was also wondering for a pair of radial T/A's if $80 a tire is a good price... thanks
no318
Tire size isn't a problem.  May depend a little on back spacing.
Dave22443
I have 235x60x15's on 15x7 Magnum's on the front of my '68 Charger with 4.5" of backspacing and have no problems of any kind.  Out back, I just upgraded to 195x50x15's on 15x10 Magnum's with 5.0" backspacing.  Clearance on the rear fender is too tight though, causing tire rub when compressed.  Now I have to add air shocks which I really didn't want to do, but the "steam roller" look is pretty impressive  :yesnod:
I would say that in your case, if you went with 4.5" backspacing on all of your rims (front and rear) you should be fine.
-Dave
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
- Abraham Lincoln
no318
Dave,
Any pics of yours with the 10" rims?
Kevin
Dave22443
I took some, but it was in the shade and they didn't really come out (you can't see the tires).  Will take some in the sunlight once I adjust the ride height and post'em up.
Thanks for asking!
- Abraham Lincoln
