dash adhesive/sealant
Started by Recharger, June 05, 2006, 11:57:20 PM
Recharger
Does anyone have any recommendations for what adhesive to use between the dash & cowl?  (I've got a 68 if it matters)  I'll hopefully be putting mine back in soon and wasn't sure if any good adhesive at a hardware store would do the job or if there was a specific type or brand I should look for.  Thanks for the help.
4402tuff4u
Good question! I'm ready for this too.
"Mother should I trust the government?........... Pink Floyd "Mother"
Doc74
Is this just to make sure there's no leaks? I don't think it has to really be glued on it.This is just to put betwen the dash and cowl so it's snug ?
I'd use something like 3M seam sealer which adheres very well to just about all clean surfaces, it's elastic so it last a long time and you can paint over it directly in case you want to.
If you really want to glue it in you need a windshield glue, same type of cartridge which you can apply by hand or with a caulking gun.
Don't get any of those bathroom caulks, they really don't work all that well in a car...unless you have a bathtub in it..
There's plenty others besides 3M with the same qualities and some for less money but I really can't think of any brand names right now.I'd go for the 3M anyway, you're sure to have quality then.
Hope this helps, if not...ask again  :icon_smile_big:
4402tuff4u
When I removed my dashboard prior to droping of the Charger to get totally media blasted, I had to remove a thick layer of sealer so that I could exposed the bolts to unbolt the dashboard at the windshield area. This sealer was pliable and not rigid. I was able to remove it with a screw driver and once up you could peel it off. This Sunday I have a guy that works for a large car interior restoration place installing my headliner "on the side" and I'll ask him what stuff they use.
Doc74
Quote from: 4402tuff4u on June 09, 2006, 01:25:57 PM
That very much sounds like auto body caulk and it's what I'd use. It seals, protects but is removable if you wish so.
if it is the stuff i am thinking of  , it was under my windshield gasket and covering  some of my dash bolts of my 69 , windscreen guys used this stuff all the time , before the the days of bonded in glass , it is a permanently flexable black water proof sealer that is layed in the channel before the gasket is fitted , Kent industry's sells it so does 3M part # 08509 i believe
Recharger
Thanks for the input guys!  That black stuff you mentioned sounds exactly like what I encountered.  (just FYI, a little brake cleaner works like magic to clean that stuff up).  So, is that stuff just put down on top of the dash as a sealant for the windshield gasket, or did they put it between the dash and cowl also?  It looked to me like it was put between the dash and cowl as a seal, but in retrospect it may have just seeped down in there from the windshield channel...  Any ideas?  would it matter?
Quote from: Doc74 on June 09, 2006, 01:16:49 PM
How did you find out about my body-mod plans?   :D
i would of thought it was squeezed out of the windsheld channel , as the glass was eased in to place, . the factory method called for a large wide bead of sealer along the bottom  channel & about 5" up the windshield pillar , with an extra amount in the bottom corners.  you must repeat this  when fitting the wind shield other wise it will leak .  my windshield had never been out until i done the resto , and it was like this.  spraying  WD40 and rubbing it off with a rag  is also good for removing this  can be a bit messy though.
4402tuff4u
Quote from: Recharger on June 14, 2006, 09:55:24 PM
Mine did not have it in between the cowl and dashboard. Just had over the bolts and the whole area. Once I removed all the sealer, the paint underneath looked as new as day one!
