engine bolt leak
Started by jim conway, April 07, 2025, 06:40:36 AM
jim conway
 I have intake manifold bolts to aluminum heads leaking oil l/s on my 440 . Any ideas what the problem might be  ? Thank you
Use Permatex Aviation Form-A-Gasket on the threads.
Kern Dog
All intake bolts need some sort of non hardening sealant.
The underlying problem is crankcase pressure pushing the oil past the bolt threads. Do you have a functioning PCV valve? An engine with a good crankcase vacuum system won't have that problem.
