pcv valve flow rate?
Started by Tigger, May 11, 2023, 02:16:54 PM
Tigger
For a 69 with a 383 is there a procedure to measure pcv function? is there a spec? Does modifying engine change the pcv valve requirements?
they used the same PCV valve in the slant 6 all the way up to the Hemi....all it does is suck the vapors out of the inside of the engine into the combustion chamber....engine modification won't matter
