Back up and Running
Started by kent, February 15, 2023, 05:09:37 PM
kent
Glad to have you back up and running.  :2thumbs:
Kent
70 sublime
Good to see it back up
Had to find my log in password  Glad I wrote it down someplace
6pkrtse
1963 Belvedere 413 Max Wedge
1970 Charger R/T S.E. 440 sixpack.
1970 Challenger R/T Drag Radial 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Road Runner 383 4 BBL
1974 Chrysler New Yorker 440 4 BBL
1996 Dodge Ram 2500 V-10 488 cu in.
2004 Dodge Ram 3500 CTD Dually 6x6
2012 Challenger R/T Classic
hemi-hampton
Does this mean it will be easier to post Pictures now :scratchchin:  :shruggy:
Quote from: hemi-hampton on February 15, 2023, 10:17:10 PMDoes this mean it will be easier to post Pictures now :scratchchin:  :shruggy:
Unlikely. All the changes and still no automatic image resizer.  :brickwall:
Aaaaaaaannnnnnnnd I have a good idea why people whine about it too as I recently switched to an iPhone and that POS has the capability of doing every photo editing trick imaginable except resizing.  ::) I'll play with whatever settings I can but I may need to add an extra "plugin" to help with the uploads.
hemi-hampton
It's not only resizing which is minor to me but then you can only post the pictures once or have to rename. I've had it say rename or already used on a pic i never posted or gave new name to? :brickwall:
Quote from: hemi-hampton on February 16, 2023, 12:34:23 AMIt's not only resizing which is minor to me but then you can only post the pictures once or have to rename. I've had it say rename or already used on a pic i never posted or gave new name to? :brickwall:
That part is fixed. No more unique name filter and when there's an error in a post it saves it all so you can edit.
kent
Great to hear Troy. That part was kind of frustrating for sure. :2thumbs:
Clicking on the picture. makes it viewable.
Kent
dkn1997
Quote from: Troy on February 15, 2023, 11:33:07 PM
This is likely old news to a lot of people but its relevent:
I'm also an iphone user.  I email the pictures to myself on my iphone.  It gives you the option for size when you go send. "medium" is what I've found works for this site.  Open your email from yourself and save the now resized pics.
For my PC i usually drag pics into MS paint and resize.
RECHRGED
4cruzin
Awesome job Troy!  I'm sure it is no small undertaking!   :2thumbs:
Tomorrow is promised to NOBODY . . . .
6.7Cummins
1968 Charger R/T 440/727
C500
Thanks Troy, good work. When you adding pics on a post using an iPhone, it gives you re-size options for the image as soon as you select the image. No need to re-size first.
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
Quote from: C500 on February 16, 2023, 04:39:46 PMThanks Troy, good work. When you adding pics on a post using an iPhone, it gives you re-size options for the image as soon as you select the image. No need to re-size first.
It does now or it did before? Because that seemed like a huge problem that most people couldn't overcome. Look in the help section to see all the threads.  :lol:  :lol:
C500
Quote from: Troy on February 16, 2023, 06:39:52 PM
On the old forum it could be done quite easily, but I tried it now, and there is no option to change the size after selecting the image on iPhone.
hemi-hampton
Being a Caveman I'm not on a iphone or anyphone. I'm still on my big widescreen Computer, which makes it easy to resize using photo shop. LEON.
P.S. Just tried to insert image & now I cant add picture without having a URL address? What the Hell, I never had to have a URL before? whats going on here?
hemi-hampton
Plus it's 10:50 pm here but post sez 1:50 am? What time zone are we in? China Time Zone?
hemi-hampton
cdr
Thanks for all your hard work Troy !!!!
hemi-hampton
I can't post a pic unless I'm replying to somebody :scratchchin:  :shruggy:
Quote from: hemi-hampton on February 16, 2023, 08:50:16 PMBeing a Caveman I'm not on a iphone or anyphone. I'm still on my big widescreen Computer, which makes it easy to resize using photo shop. LEON.
I have no idea what you're doing. Make sure you open the attachment pane. You can use a file selector or even drag and drop the picture (from your hard drive not a web site or Facebook). Hit upload. That's it.
Quote from: hemi-hampton on February 16, 2023, 08:51:39 PMPlus it's 10:50 pm here but post sez 1:50 am? What time zone are we in? China Time Zone?
The server is in Eastern time but I did notice that something must have reset the time offset (look in your profile). It seems like everyone is a few hours off. Mine seemed to think it was UTC.
birdsandbees
Quote from: hemi-hampton on February 17, 2023, 12:32:57 AMI can't post a pic unless I'm replying to somebody :scratchchin:  :shruggy:
I was going nuts myself... just realized you have to hit REPLY at the bottom of the page to get the file download box, you can not use the "Quick Reply" box...
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
Homerr
Troy, is there a plugin that will randomize an image name upon upload?  Or at least add a randomized suffix to images?
You upload:
and it randomizes to:
Quote from: Homerr on February 17, 2023, 12:34:50 PMTroy, is there a plugin that will randomize an image name upon upload?  Or at least add a randomized suffix to images?
You upload:
No? Well, I'm not sure why we'd need it. The duplicate name problem has gone away.
Having said that... the file name behind the scenes is a unique "hash" so it never duplicates. THIS is what caused me the problem all those years ago when people kept uploading the same picture hundreds of times because they wanted it to show up on every post and couldn't grasp the concept of an avatar. That's how the setting got turned on to block duplicate file names (then SMF changed their coding and removed the ability to change that setting back).
Quote from: birdsandbees on February 17, 2023, 08:51:00 AM
If you preview your post from the "Quick Reply" you can add a picture.
cdr
cdr
More test My Charger & a new Super Stock Challenger
hemi-hampton
Yeah, The Quick reply does not have a Attachement Option. And the insert image option at top wants a URL Address :scratchchin:  :shruggy:
hemi-hampton
test
still trying to figure it out, it was actually easier before & that was hard enough.
P.S. Click on pic to enlarge.
hemi-hampton
hemi-hampton
hemi-hampton
birdsandbees
Once you select your picture, then hit upload to insert it into the post full size.
birdsandbees
Quote from: hemi-hampton on February 17, 2023, 08:26:59 PM
I know it's subtle but "insert" is not the same as "attach". The buttons at the top are to "insert" something into the text of your reply. Hence, a link (URL) is required. "Attach" uploads a file to the server and displays it after the text in the post.
birdsandbees
Well I've got Attachments and other options.. "add files"... "upload"... "insert".
moparstuart
